Good compression - losing coolant through #6 cyl
Old Dec 21, 2017 | 08:16 PM
fin reaper's Avatar
Head gasket replaced 5k ago.
Compression: 1-180; 2-175; 3-180; 4-175; 5-180; 6-180
Spark plugs removed, I can see coolant misting through #6 spark plug hole when the starter is engaged.
Where can this coolant be coming from, without affecting compression? I do see steam in my exhaust, more when it's just started - already warm or cold...
94 4runner 3.0 manual
Old Dec 22, 2017 | 02:30 AM
wyoming9's Avatar
Red face
How much coolant have you added ??
Seems like you have a leaking intake manifold
valves are sealing fine and the rings so good compression numbers
Do a Coolant system pressure test
Old Dec 22, 2017 | 06:03 AM
fin reaper's Avatar
Thanks - forgot to mention. I did a coolant leak down test and it would gradually lose pressure while static. When I turned the engine over with spark plugs in - no increase in pressure. I suppose this also leads to intake man and or cracked head (upper intake side).
Any suggestions on the intake man? Take it off, inspect and put it back on with new gaskets? Should I have it magnifluxed?
Old Dec 22, 2017 | 03:25 PM
Thommo Thompson's Avatar
the intake gasket is a common fail point on all vehicles. rest assured its probably just that. rip it off and confirm.
Old Dec 22, 2017 | 03:34 PM
fin reaper's Avatar
I found an exposed 3.0 intake at the JY today. It would be great if it was just the gasket, but it seems a stretch that water could leak into #6, with a bolt in between from a bum gasket. I'd think the valley would be the first to see an intake gasket leak. See attached pic.
Old Dec 23, 2017 | 02:32 AM
the bolt is probably the problem. they usually go into the water jacket and cause the issue themselves.
u saw coolant right? u sure it wasnt fuel haha?
its more likely a gasket than a crack.
Old Dec 23, 2017 | 06:10 AM
fin reaper's Avatar
Gotcha. I'll borrow a flexi-camera to feed down the #6 intake to try to learn more before I tear into it.
Old Dec 23, 2017 | 02:56 PM
yeh im hoping for u that its just that!! wouldnt that just be nice.
Old Dec 23, 2017 | 02:57 PM
in fact ull notice if u look at that pic of the JY thing, the bolt holes at the end, are rusty! and the others are clean. id say its a common issue
shwuz
Jun 19, 2020 09:33 PM
thetundrawolf
Jan 21, 2014 06:57 PM
DupermanDave
Dec 27, 2008 10:49 AM
baileymoto
15
Mar 23, 2004 07:52 PM
