95 4Runner 3.0 CRANK NO START...
Old Feb 19, 2018 | 12:18 PM
Tmv1011's Avatar
Hello all who are willing to put up with my problems and help me out. Ok so I had another posting that was about the fuel pump mostly that was a while back and I have since got the fuel pump working. Now that did not solve my issues whatsoever... I have a strong spark to the plugs, its getting gas through at least the cold start injector, and my timing belt is intact and good. I have sprayed starting fluid into the throttle body to see if that helped to no avail. I will need to swap out my battery most likely after this but i was definately wanting to fix the issue at hand first. Any ideas world of Yota??
Old Feb 19, 2018 | 01:03 PM
scope103's Avatar
Not even firing?
Really low compression would do that. It's a $20 tool to check it.
Timing way off would do it; another $25 tool. But you could be 180° off and the mark would end up in the "right" place. You might need to remove the valve cover to compare the valve position to the distributor rotor.
Cam off should show up as low compression.
Old Feb 19, 2018 | 01:12 PM
Tmv1011's Avatar
Much appreciated! I will rent the tools and check it out tomorrow. Hopefully I will get some answers out of that.
Old Feb 24, 2018 | 06:25 PM
Tmv1011's Avatar
I finally got off work in time to do some digging and checked the compression. All cylinders are at 120... Im going to look at the timing some tomorrow while im off. Anything else i should probably look at while im out there?
Old Feb 25, 2018 | 06:14 AM
Tmv1011's Avatar
Ok starting the day off. Im going to keep an eye out on the forum so i can see if anyone has an idea while im doing this. Going to go ahead and recheck all the spark to plugs since i already have them all out as well.
Old Feb 25, 2018 | 09:04 AM
akwheeler's Avatar
Please confirm, when you use starting fluid (just a little) you don't get any signs of cylinders firing?
t3banshee
May 4, 2014 09:01 PM
4Mainer
Mar 9, 2013 03:58 PM
5.9ford
Dec 6, 2012 05:20 PM
hermyboy3000
Aug 19, 2012 12:19 AM
meighant
Oct 6, 2009 03:04 PM
