97 limited 4runner No crank no start
Old May 4, 2014 | 12:25 PM
t3banshee's Avatar
Just bought a 97 limited toyota 4runner with 3.4 v6 and auto transmission.
Wont crank over. No clicks. all lights and everything works
good battery
new starter
maybe neutral safety switch?
i can jump the starter and starts up and runs.
i ran new battery cable and no luck as well.
anyone have wiring diagram for Neutral safety switch so i can bypass it to see if the switch is bad because those are expensive!
thanks
Old May 4, 2014 | 01:32 PM
rworegon's Avatar
Have you carefully checked all the fuses?
Old May 4, 2014 | 01:51 PM
FJHammerHead's Avatar
Someone else recently had the same problem and it was a bad cell in the battery. They thought the battery was good because it was only 1.5 years old.
Old May 4, 2014 | 02:06 PM
t3banshee's Avatar
i have check all fuses and they are good. i replaced the starter relay as well.
i have hooked to a big battery charger as well. hmm maybe the battery is junk! when i turn the key to crank the engine over the clock and radio lights go dead as if it cuts the power. battery holds 12volts but like ya say not always good. i was thinking it was a ground issue.
thanks
Old May 4, 2014 | 03:37 PM
rworegon's Avatar
Should be holding more like 12.6-12.7v......12v is about a 50% charge on an auto 12v battery.
Old May 4, 2014 | 08:23 PM
t3banshee's Avatar
figured it out! the aftermarket alarm previous owner had was tapped in to the signal wire for the starter solenoid. well cut that crap out and it starts. not bad i guess for $1200 bucls.
Old May 4, 2014 | 09:01 PM
rworegon's Avatar
Good work! Enjoy your ride.
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
Ichneumon
Sep 27, 2015 04:21 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
