Replace rear main seal while flywheel is out?
Old Feb 13, 2018 | 04:13 PM
Paul22RE's Avatar
5 Year Member
1992 22RE pickup has 120K. Should I replace the rear main seal since it will be right there? Any special tool I will need to set the new one in?
Old Feb 14, 2018 | 03:05 PM
wyoming9's Avatar
Red face
One of those trick questions!!
Only you can make the call
If it is not leaking I don`t mess with it.
Last 10 clutches did not change any .
Old Feb 16, 2018 | 09:27 AM
gsp4life's Avatar
I agree with wyoming9.
If you ignore that advice and replace it, use a new Toyota seal which is shallower than the old one (as well as new aftermarket seals). Rear mains can leak from the rubber wearing a groove in the crankshaft, so by moving the sealing lip, you fix that problem.
Mine leaked, so with the housing on a block of wood, I tapped the ungreased seal in place with a plastic mallet and a pvc tube that fit along the outside of the seal. You can replace it without removing the housing, but only if you're absolutely sure the housing gasket isn't leaking.
Old Feb 17, 2018 | 03:10 PM
Paul22RE's Avatar
5 Year Member
Seems it will be much easier if I take the complete housing off to change the seal, what is the disadvantage of removing the seal housing? Causing a possible break in the oil pan gasket?
Old Feb 17, 2018 | 04:18 PM
gsp4life's Avatar
Would definitely cause a break in the oil pan seal. It's just fipg (or at least should be).
I've never replaced a rear main seal with the housing still on, but I also imagine it's easier while off the engine.
Old Feb 18, 2018 | 04:23 AM
Paul22RE's Avatar
5 Year Member
So the entire housing also uses FIPG? I did look for a part number for a gasket and could not locate one, this makes sense if it is FIPG.
Old Feb 18, 2018 | 05:19 AM
gsp4life's Avatar
Well, you can use fipg behind the housing but there's a fiber gasket designed for it. Used to have the bag with the part # on it but can't find it now., Any dealer can bring it up.
I was referring to the underside surface of the housing being part of the oil pan's fipg seal. Each time I've pulled the oil pan, I had to cut all the way around with a razor, including under the rear main housing to help it let go.
Old Feb 28, 2018 | 04:03 PM
Paul22RE's Avatar
5 Year Member
The new Toyota seal is not as thick as the one I pulled out which is what you did mention, and is a good thing so the seal won't ride on the same spot. One question: Should I set the seal completely into the housing stop & not just flush with the housing as the original one was? It will ride further in which I assume is correct, and will not be flush anymore with the housing. Thanks.
Old Feb 28, 2018 | 04:12 PM
gsp4life's Avatar
The new seal is meant to be seated as far in as it can go. If you put it in flush, it would ride on the same part of the crankshaft, and also I imagine it would be difficult to get it perfectly level.
Anyway, I tapped it down as far as it would go back in August 2016 and it's never leaked a drop. Don't forget to use some mp grease on the inside lip before putting it back onto the crank.
hiluxury
Sep 27, 2010 04:40 AM
flyingbrass
Nov 4, 2009 02:29 PM
live4soccer7
Sep 22, 2009 12:03 AM
mtrdrms
Jan 8, 2008 03:44 AM
EOD30
Sep 21, 2004 05:18 AM
