- Differences Pickup/Taco IFS
- 1988 4Runner Axleshaft Seals (Front IFS)
- Over filled oil
- can't find my flasher.
- ANOTHER CB thread...
- 1st gen 4runner brush guards?
- Axle Swap
- Blown axle seal
- Trying to put oil pan back on
- winch?
- Farewell for now to yotatech
- 63 chevy rear shackle mount
- glasspacks on 22r 4x4
- Technical help please
- 3 Q's
- FRAME SWAP!!!!!!!! Some1 knows
- fuel gauge not working
- Question for Anyone that's Installed an Allpro Rear Tube Bumper on a 2nd Gen. Pickup
- 4Runner/Roof Rack
- Interior Switch
- My new 2nd gen 4runner!
- Gauge Temp Sensors-22RE
- Dealer and truck problems
- Leaky Head Gasket HELP!
- what would you do about this exhaust leak?
- 3.0 Oil port for mechanical Oil gauge
- 22re help
- Westbank, BC - Pick 'N' Pull Yard
- Marlin Crawler Clutch
- Vacuum Gauge Hook up
- 2nd gen runner model on ebay
- A big Thank You and some spring questions
- Overdrive Problem, help anyone???
- 2008 Iguana
- Leaky tranny line???
- Damsel has returned... back in distress!
- fuel tank woes
- Finally gonna get a runner...
- 3.0 Transfer Case Rebuild/parts needed
- cheap and effective mods
- engine codes... what to do now?!?!
- sky's shock relocation kit
- Help with Valves/Cylinders
- intake gaskets
- rear window won't move
- 3.D'oh Sensor Block - Vac Line
- Got me a new toy today
- Lighting...Hella, Bosch or Other
- clutch slip?
- SHOCKS (What Ones?
- 86 Rear Window Stopped Working
- Need body help asap!
- What is everybody working on today?
- 1991 4Runner SR5 question
- cel codes
- Wiring harness ?
- 3.0 idle speed at operating temp
- tune up questions
- Header Fit for Right Hand Drive?
- Volvo turbo 4cylinder in a Toyota truck
- Do my new tires exist?
- AAMCO Adventure
- Let's talk about 22RE swapping a VAFM from Supra's and Cressida's
- New 85 4runner!
- Is there an IAC on the 3.0?
- 88 FOR SALE / What should I ask for it?
- Information On Trailmaster Lifts Anyone???
- question about the fan on a 22re
- acceleration problem please help
- oil pressure gauge
- Help with '90 4Runner Fast Idle
- Tailgate Problems
- Need help with my 91
- new parts, still won't start, going crazy
- 1989 4Runner Rear Window Wiper Arm...
- cold start fuel injector
- insane power
- arb bumper w/body lift?
- solid axle swap info
- clutch pedal pressure
- best toyota video ever!!!!
- spark plugs keep needing replacing ,bad gas milage where to look
- Am I worried about nothing?
- 1990-1995 4Runner RECALL
- Running rough at idle.
- Who sells bolt on sliders?
- oil leak from back of engine
- 22RE - Findings and Vacuum Question
- winch mount
- Rolled my truck
- How to remove factory Sticky Stripes?
- the limits of your truck
- my v6 is running way to rich
- springs from an 85 pick up on an 89 4runner??
- ISR mod = Bad mileage
- 3VZE helpful mods
- T Bar question
- Downey Header Noise??
- difference in width between pickup and tacoma? (re: arb bumper)
- Miss, stutter, buck, rough idle...HELP?!?!
- alarm install quick central locking question
- So i found what i think is a good deal
- Redline MT-90 or 75W-90
- IFS axle tube torx bolts.....
- Good AfterMarket Suppliers
- piston rings
- Wipers stopped working - bad motor? hidden fuse?
- 4runner won’t start Help
- head bolt torque spec
- Keyless entry not working
- Rough and unstable idle????
- What to watch for when buying a 2nd gen 4runner?
- fuel gauge doesnt work.
- Driveshaft Rebuild - Is it really that expensive??
- NWOR Skidplate Quality
- Truck not starting again!!!!
- Finally the toy I wanted
- General Spring brand rear leafs???
- 3" performance accessories lift
- higher clearance crossmember options?
- Is my auto tranny dying?
- V6 T-case Xmembers
- yeah the transmission thing....
- bushings
- Can anyone please recommend an offroad shop in NJ who specializes with toyota's
- Clutch problem????
- Help with ground wires on 86 4runner
- O2 sensor on 22R
- What is a intake air temp. sensor?? (3VZ-E)
- another gauge swap issue (kinda)
- 1991 4Runner SR5 V6
- Might have stumbled upon another deal??? advice?
- Cam suggestions, already tried engnbldr 268
- Coleman Cargo Basket Mounting
- engines stall when I hit the gas
- ? for BudBuilt Owners
- My 900 score
- grill guard
- Running WAY too rich
- V6 3.0 Y Exhaust Pipe
- 4WD trouble
- Rough idle, excessive fuel consumption?
- Rust Repair?
- 90 4Runner, spare tyre
- Engine stumbles: Advanced ignition timing, 5 degree BDC?
- lc engineering clutch quality
- 4" Suspension 3" Body lift, what size tires
- Shifter moved to the floor
- Anyone In The Vegas Area! Huge Deal!!
- Turn Signal Questions
- Cold Start Pics ??????
- coolant leak or something
- wind sheild wippers
- Cracked head....
- EGR filter
- 22re gain in power
- 87 4Runner CEL code 11
- Guessing it's a head gasket
- 4Runner Top off Questions!!??
- Temps after HG replacement
- Driveline Vibrations
- Charge Light + High Idle = ?
- Marlin & LCE are stopping the sell of 4runner
- 33's too big?i have
- Anyone have those little center caps
- 3.0 3vz-e Rough Idle
- Windshield wiper motor
- Fuel injectors - replace or rebuild
- Bet nobody's done this before/HG "problem"
- 22re engine swap out time
- W56 Tranny Rebuild. Experiences?
- When new Coil Spacers go bad!
- 2nd Gen. 4runner bumper
- recommended shocks
- lower radiator hose replacment tip
- lets see your bobed beds
- Antifreeze leak...found...but no gasket!
- Did a tune up, now I have a miss
- 88 pickup seats
- Gear Oil Spraying Rear Tires/Undercarriage/Differential
- Spark Leaking!! Power loss
- whitch one?
- Rear window relay fix- 1990 4Runner
- Feeler: Drive Flanges
- So my engine ate a washer....
- Detroit TrueTrac / Front IFS Questions
- 22r Oil Galley Plug Questions...
- rear end locking options
- Kick Up/Down Cables??? Kinda Long
- Transmission HELP!!!???
- speed sensor
- Does this Bilstein install look right?
- Need help identifying 3VZE engine/trans bracket
- Dash lights/stereo issues 1st gen 4runner
- 22re knock sensor code 52
- cluster question not what you think!!!
- question - spool installation
- 4 runner power issues
- Need your Knowledge
- 1990 pickup problem
- YEs , I know seafoam? # another!
- Who is using superlift Superide shocks??
- First 10 emails get free decal! ALL GONE!
- Need some main/rod bearing input, if you please...
- BJ Spacer idea
- 3vze sequential injectors?
- Tractor Lights vs Driving Lights
- check it out... ill let you in on a little secret..
- Where to get Sunbrella material?
- Annoying Noise, what can this be? (see video)
- Top shock bolt not reuseable (front shocks)
- just had my 94 weighted at a certified public scale
- 91 pickup no fire after blown head gasket
- Timing chain rattle or what ? Help !!!
- Injector pics??
- 32 11.50 are they to big
- Craigslist find - Calgary
- truck hard to start
- Body Kit Help
- I need some spare 4runner wheels for snow tires...
- code 14 and 71
- 87 4runner SAS lift ?'s
- 93 4x4 pickup vibration @ 55mph
- 3.0 trasmission trouble
- Truck won't start after head gasket replacement!!!
- Fuel tank lift - unsuccessful
- So i just sold my OLD catalytic converter for...
- Clurtch Slave
- 1988 22re
- '89 22RE Rebuild
- Need Advice, Selling 1990 4Runner with cracked head
- 93' 22re Motor/Smog Help
- 88 fuel injection harness
- CEL!....its not the O2 sensor
- strange leak question
- Bearing preload to tight???
- any help is great
- calling all toyota certified techs!! (long)
- 88 camry guage cluster swapped into 89 pickup
- hood pop not working...
- Need advice on all fluids!
- How to ID a geared TC?
- Puled Air Injection System Necessary?
- Aisin spring??
- what to do about the undercarriage?
- 3.0 Diagnosis question
- Rod Ends for SB Disconnects
- Broken Connector
- I think I know why the PO bought my 4Runner for 1,500
- 1st or 2nd gen 4runner?
