auxiliary fuse box ?
Old Feb 6, 2008 | 09:57 PM
blue87's Avatar
who here has installed an auxiliary fuse box for extras. when this is done is it switched power of coinstant?
where can i get a fuse box for this. ?
Old Feb 6, 2008 | 10:06 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i have. constant power, got it at autozone. you can get better sealed ones at some auto parts stores or maybe home depot if youre lucky
Old Feb 7, 2008 | 03:10 AM
GSGALLANT's Avatar
I have a 12 circuit (30 amp max per circuit with a maximum of 100 amp total for the block) blue sea systems blade type fuse block (shown here.) installed with constant power from my auxiliary battery. I mounted it on the cover of the airbox (the part that flips up when you want to remove the air filter. It's a perfect fit. I just leave a bit of looseness in the wires right at the box so that it doesn't prevent me from opening the air filter access door.
So far, I only have a voltmeter and all my 12V outlets wired to the aux fusebox. When I get some time, my driving lights will get wired there also.
Old Feb 7, 2008 | 03:29 AM
TORTIS's Avatar
this is what i did. i think this is Corey's idea.
http://pnw4runners.com/tando/modpics4.htm
Old Feb 7, 2008 | 04:45 AM
Squiddy's Avatar
Painless wiring makes a variety of them, very easy to install. Hook to battery with fuse in between.
choppe777
May 16, 2016 08:00 AM
Gone Fission
Sep 4, 2015 12:18 PM
39 Thieves
Aug 31, 2015 12:51 PM
Mrhoadley
Aug 4, 2015 06:08 PM
rushw
Jul 18, 2015 01:46 PM
