cel codes
Old Feb 16, 2008 | 09:36 AM
art's Avatar
art
cel codes
I have a 89 p/up 22re. The cel light shows codes 51 and 71. Switch sensor and egr system. Codes found here. www.troublecodes.net/Toyota/ How important are these the fix right away? Are they a PITA to replace? What is the switch sensor? Does that mean I have to replace the egr valve? Yotatech has helped me with many things before. Thanks folks!
Old Feb 16, 2008 | 04:45 PM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
Did you try disconnecting the battery to clear these codes? Code 51 and 71 are retained in the memory of the ECM. I recently had a code 51 after a long battle with a no spark condition with my 3.0 and I took about three or four times to clear it.http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
look at pg. EG1-113 it will explain what I said.
Old Feb 17, 2008 | 02:03 PM
art's Avatar
art
I cleared the codes and drove about 50 miles. No new code. The engine ran fine before the light came on. It still runs good. I'll run some seafoam through it and some throttle body cleaner. Thanks.
Old Mar 17, 2009 | 06:16 PM
art's Avatar
art
OK. now the codes are back. Truck runs fine just those codes pop up about every 500 miles or so. Any suggestions?
Old Mar 17, 2009 | 06:44 PM
abecedarian's Avatar
71- two things can cause that. the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp, or the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp. the first one could be a faulty temp sensor on the EGR valve and the second one could be a restricted EGR passage.
51 is a "switch signal" meaning, IIRC, the TPS is not signalling IDL to the ECU, the clutch switch was on or the a/c was on.... but I could be wrong.
Old Mar 17, 2009 | 10:42 PM
art's Avatar
art
Thanks for the suggestions. It did pass a smog check about 100 miles after clearing the codes.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
