Front Drive Shaft
Old Mar 17, 2009 | 10:04 PM
West Hawaii (808)'s Avatar
Cool Front Drive Shaft
I recently s.a.s my 1990 4-runner. The front axle is from an 85. A buddy of mine has the trail gear ten inch slip shaft and the flange on the t/c doesn't match. It's a 4 inch trail gear i.f.s eliminator kit. Any suggestions on how to obtain a front drive shaft would be greatly appreciated.
Old Mar 17, 2009 | 10:10 PM
abecedarian's Avatar
Thanks for starting your own thread about your truck.
Since mine is still IFS, I can't help you directly with the front driveshaft (a.k.a. propeller shaft) but I'm sure someone will respond soon with some information to help you.
Old Mar 17, 2009 | 10:16 PM
Plumbrbob's Avatar
You can buy a triple drilled flange or obtain a flange withthe correct bolt pattern.
I have run across this problem before and drilled a new bolt pattern in the stock flange.
Old Mar 17, 2009 | 11:46 PM
KONASTAR's Avatar
Howzit'!
We bought the same 10" long travel shaft from TG too.
But we bolted the 10" shaft to the pinion flange (axle side) instead.
You may have to reuse your stock front driveshaft, cut out the short slip-shaft (cut it to length) then weld the new TG 10" shaft to it.
Hope this helps..
Aloha! Mike
___________________________________
85 Toyota Std cab, 4X4
SBC 327 .040 roller, TH350 B&M, NP202 twinstik
Narrowed Dana 60 rear, 35 spline, Detriot locker
Narrowed Dana 44 HD, Ected locker, CTM's
High steer, PCS hydraulic assist., Dynatrac covers
Tom woods shafts, Twin line locks
99 Toyota 4-Runner 4X4, Std. (wifey's)
E-locker, 4:56 ratio
3" Downey suspension, 3" body
K&N air filter, MSD ignition
33 MTZ's, Weld 16X12's
69 Jeepster Commando 4X4
(original 27k miles) my daily driver
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
