question about the fan on a 22re
My 4runner started overheating and i was looking around the engine and knoticed the belt for the alt. was gone, it looks like it also goes to the pully on the fan, my question is when the fan is spinning is it turning gears/impeller in the water pump?? I hope the new belt will fix it, thanks for the help
another question... the alt belt is on the last pully on the crank do you have to take all 3 off to be able to slide it on? the timing plate is in the way... thanks
nevermind i see theres bolts on the timing plate, looks like its goin to be a pain in the dick any suggestions
Timing plate? What do you mean? You shouldn't have to take anything off except the two belt in front of it.
Take off the a/c and power steering belts, slide them over the fan, slide the new alt. belt over the fan and onto the pulley and alt. Then, replace the other two belts.
the1998sr5
15
07-14-2020 08:35 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
