What clusters are compatible with my truck
Old Feb 7, 2008 | 08:02 AM
ovrebo1's Avatar
I have a 94 22RE with a base model cluster. I would like to install a SR5 cluster. I would like to know what clusters are compatible with my truck. I saw one in a early model tacoma at a yard, would that one work even though its from a different generation. thanks
Old Feb 7, 2008 | 08:09 AM
Yodaforce's Avatar
In order to simplify things at the assembly plant, most all of the same models were made compatible. When models change however, wiring changes (a little) so you would just have to compare the connectors on the back of them both (and wire colors).
Old Feb 7, 2008 | 08:20 AM
ovrebo1's Avatar
would one out of a v6 one work. or out of a early model tacoma
Old Feb 7, 2008 | 08:48 AM
kayakken's Avatar
no the tach wont work right
also disconnect your oil sending unit or you will blow the gauge
mine in the 84 is toast
buy the right oil sender from a parts store
Old Feb 15, 2008 | 05:16 PM
ovrebo1's Avatar
has any one ever tried to use a tacoma cluster in a 88-94 truck
Old Feb 15, 2008 | 05:28 PM
just a 22re's Avatar
no i never have but im still trying to do the digital dash in mine though would be sweet
Old Feb 18, 2008 | 01:48 PM
ovrebo1's Avatar
to answer my own question since i guess no one has tried this, but they are different, but im going to try and re wire the tacoma cluster and make my own trim bezel
Old Feb 19, 2008 | 07:27 AM
ovrebo1's Avatar
Unhappy
wires are to complicated. i give up. i ordered an autometer tach
Old Feb 19, 2008 | 07:56 AM
isaac338's Avatar
wow, 24 hours later... that was quick
Regency
Jan 16, 2016 07:33 PM
irish_tyrant
Jul 6, 2015 11:22 AM
MadMax48
Jul 3, 2015 08:26 AM
streetuner15
Jun 18, 2015 10:59 PM
NerfHerder-97SR5-
Jun 17, 2002 05:31 PM
