So my engine ate a washer....
Old Feb 10, 2008 | 05:38 PM
91slowrunner's Avatar
Question So my engine ate a washer....
Well here's the deal, I pulled my passenger side head of my 3.0 today. I was removing the head bolt closest to the firewall and the stepstool i was standing on slipped. Well you know that washer? Yeah it slipped off the bolt and fell right down the hole that returns oil back to the case. Any ideas or wisdom guys?
Old Feb 10, 2008 | 06:07 PM
ozziesironmanoffroad's Avatar
pen magnet
Old Feb 10, 2008 | 06:27 PM
1 tried that....the passage is quite small
Old Feb 10, 2008 | 06:53 PM
rowdy235's Avatar
Drop the pan?
the pen magnet i have is as big as a stereo antenna. its smaller than that? then how'd the washer get in there? lol
Old Feb 10, 2008 | 06:54 PM
Originally Posted by rowdy235
Drop the pan?
i was gonna suggest that next
Old Feb 10, 2008 | 07:14 PM
CJM's Avatar
CJM
Drop pan or get a good piece of fishing line and get a very small magnet. it will fetch it right out.
Old Feb 10, 2008 | 07:19 PM
AustinTaco's Avatar
Yeah, fishing line/fine string and a magnet. good luck
Old Feb 10, 2008 | 07:52 PM
Matt16's Avatar
The block is magnetic, a magnet on a string will just stick to the sides of the passage. Try the telescopic magnet.
Old Feb 10, 2008 | 08:40 PM
The magnet would not fit through the passage...it is about two washer widths. I am trying to avoid dropping the pan
Old Feb 10, 2008 | 08:41 PM
CJM's Avatar
CJM
Uh magnets that ya get usually are shielded so you can out them down into the engine. THey wont stick to anything but what the tip touches..
Old Feb 12, 2008 | 05:29 PM
Targetnut's Avatar
If you can't get it out you should pull the pan.
A tech at the dealership I used to work at droped a nut in the crankcase and when he started the engine the crank shoved it through the main bearing girdle and tore the bottom end up.
Depending on where it lands it may or may not cause big problems.
Old Feb 12, 2008 | 09:14 PM
stormin94's Avatar
Pulling the pan is gonna save you a lot more time than if you leave it in there...
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
