33's too big?i have
Old Feb 11, 2008 | 09:59 AM
wcc_71's Avatar
33's too big?i have
i have a 92 toyota truck with the 3.0 and i wanna put 4 inches of lift and put 33 12.50 BF goodrich mud terrains on it would them be too much for that motor? it doesnt have alot of paower to begin with. any way some peoplr with this motor can tell me how to get any power too?
Old Feb 11, 2008 | 10:06 AM
tacoma728's Avatar
Yes, it will be fine. I got 33x12.50 mud terrains on my 91 with no lift, and it still does okay. With Four inches of lift, i personally would throw on some 35x12.50s. If you go 33s now, you will regret later not getting 35s. The engine will be underpowered, but it is still very capable, especially if you crawl on trails in low. You're call.
Old Feb 11, 2008 | 10:09 AM
wcc_71's Avatar
what do you mean by underpowered
Old Feb 11, 2008 | 10:12 AM
hanksyota's Avatar
like slow as a dog. no power on anything involving a hill. is it a manual or auto?
tacoma728's Avatar
If the stock gear ratio is maintained, the engine will be forced to work harder, but some 4.88s would do it.
Old Feb 11, 2008 | 10:13 AM
tacoma728's Avatar
i personally am going to buy a set of 35s that will be interchangeable between my 91 pickup and tacoma. I don't mind the loss in acceleration due to the fact that i drive tractor trailers and am used to going slow anyways.
Old Feb 11, 2008 | 10:14 AM
wcc_71's Avatar
true lol ita a manual.. i wish the motor had more power.
Old Feb 11, 2008 | 10:30 AM
AxleIke's Avatar
Drop in 5.29's and 35's. 4 inches with 33's is overkill. Like Tacoma728 said, you'll regret 33's with that much lift.
With those gears, you'll be about stock power wise, so about like you are now. No performance loss.
Old Feb 11, 2008 | 10:31 AM
wcc_71's Avatar
aight.... 35x13.50?
Old Feb 11, 2008 | 10:32 AM
AxleIke's Avatar
If you want to stay with the BFG's, you'll be looking at 12.50s.
Old Feb 11, 2008 | 10:34 AM
wcc_71's Avatar
if i stayed with the 12.50 would they rub anywhere
Old Feb 11, 2008 | 11:06 AM
AxleIke's Avatar
Unknown. That will depend entirely on your wheel backspacing.
Old Feb 11, 2008 | 11:08 AM
wcc_71's Avatar
aight cool im prob gonna run some dick cpeck 15x10
Old Feb 11, 2008 | 11:14 AM
dropzone's Avatar
Fossilized
Do your truck, yourself and those behind you a favor: Regear
you can find Toyo Open Country MT in a 35x13.50 if you want that wide, 35x12.50's will work on an 8" rim too
Old Feb 11, 2008 | 11:30 AM
AxleIke's Avatar
Again, still will depend on your backspacing. 10" will be more likely to rub than 8".
Old Feb 11, 2008 | 11:33 AM
olharleyman's Avatar
With my Pro Comp stage II 4" lift I run 35 x 12.5's x 15 on 8" rims with 3.75" back spacing and 5.29's on my 90 4runner and yes you will have to do minimual trimming on the pinch welds behind the rear of both front tires.
It took me about 5 mins with a whizz wheel to trim mine. I went from the front door line to about 1/4 way up the welds on the wheel well and it works fine no rubbing except when stuffed pretty good.
Big Little Bear
230
Nov 13, 2023 11:42 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
ToyotaMD
Sep 22, 2015 04:49 AM
83
18
Sep 21, 2015 06:15 PM
sonorn67
Sep 19, 2015 05:39 PM
