oil pressure gauge
Old Feb 15, 2008 | 02:00 PM
owall's Avatar
Exclamation oil pressure gauge
i recently changed my oil/filter etc
now my oil pressure gauge only goes up a little
i,m not losing oil
i recently changed oil/filter again
but no change the pressure just goes up a little not passing a few millimeters
what can cause this..how do i fix it
92 hilux surf diesel 2.4ltr ln130
owall@rocketmail.com
Old Feb 15, 2008 | 02:05 PM
Jay351's Avatar
The sender might be going bad. Mine likes to sit at 0psi when not under load. Stupid crappy stock guages.
Old Feb 15, 2008 | 06:18 PM
stupid_mud_gremlins's Avatar
I'd double check how much oil is in it, just to be sure I wasn't getting a false reading after adding oil. I had a mazda that was horrible for that. There was a spot that the oil would hold onto just above the dispstick and the drop would rub off onto it on the way out giving a higher reading that what was actually there
Old Feb 15, 2008 | 06:27 PM
Targetnut's Avatar
If you suspect a problem with either the gauge or the oil pressure, I would recommend checking the pressure with a known good test guage.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
