head bolt torque spec
Old Feb 13, 2008 | 02:49 PM
ic3ss's Avatar
I'm putting the head back on my '86 22r and I need to know what the pattern for torquing down the mounting bolts are.
The final spec is 58ft/lbs, right?
Old Feb 13, 2008 | 03:39 PM
jason191918's Avatar
http://www.ncttora.com/fsm/1993/engine/11services.pdf
This is for a 93 22re. It says 58ft/lbs. Could it be different?
Here is a link for the 86 manual. You can double check there if you want.
http://www.ncttora.com/fsm/index.html
Sorry, could not find the pattern.
Good luck.
Old Feb 13, 2008 | 05:46 PM
ic3ss's Avatar
Thanks
I got the head on. I think I may have put a bit more than the 58ft/lbs on the bolts. Not sure. I also got the timing chain on and the cover on. The rest will have to wait 'till next week.
Thanks for the manual, jason.
wayne
Old Feb 13, 2008 | 05:49 PM
Targetnut's Avatar
check the manual for torque specs and tightening pattern.
Make sure the threads in the block are clean as well as the threads on the bolts. and lightly lube the threads with motor oil.
kgcwb44
Jan 29, 2023 10:02 AM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
