engines stall when I hit the gas
Old Feb 12, 2008 | 10:46 AM
tacurt's Avatar
I just got finished replacing the knock sensor wire, manifold gaskets, timing belt, water pump, pulleys, and acc belts. Truck ran fine before, other than being low on power from knock sensor code. Now when I start it and hit the gas the engine stumbles and stalls. If I let off the gas quick it will recover. If I ease on the gas pedal slowly it will rev, but misses. Idle is fine. I just replaced plugs, dist cap, wires. Timing is correct and all hoses hooked up. I'm don't know where to look for the cause.
Old Feb 12, 2008 | 08:01 PM
chugs's Avatar
both cams at tdc and pulley at zero mark? did u try advancing/retarding your timing from the distributor? twisting the distributor clockwise (down)retard, counterclockwise (up) advance...
Old Feb 13, 2008 | 11:57 AM
motoriderbc's Avatar
Is the intake tube between the Throttle body and the air flow meter torn or cracked? Might be hard to spot, squeeze the tube while the engine idles,if it's cracked the engine will stall/stumble.
Old Feb 13, 2008 | 12:07 PM
Michigan Mud Farmer's Avatar
What engine? 22re, could be TPS. If so pull off cable and see if you can rev it without the stumble.
Old Feb 13, 2008 | 03:49 PM
tacurt's Avatar
One of my spark plug boots had came loose on passengers side, didn't think to check them at first since I didn't take them off. Pushed it back on when I was going over everything again and its running fine now. Thanks for the suggestions.
Old Jul 18, 2010 | 02:17 PM
TONKATOY352's Avatar
Yes i have a simmiler prob. Mine run good on idle but somtimes when i hit gas it fall flat on its face and stalls. But other times it runs good and acks up when its warm
Old Jul 18, 2010 | 02:19 PM
Toy stalls when i hit gas
I'M READY TO GAS ON IT AND THROW A MATCH TO IT.
Old Jul 18, 2010 | 05:03 PM
myyota's Avatar
Check the TPS, if its bad it can cause the problems your having. Have you ever replaced the fuel filter ?.
Old Jul 18, 2010 | 06:05 PM
Engine stalls
YA NEW FUEL FILTER, PUMP,TUNE UP. THIS JUST STARTED AND IS DRIVING ME NUTS
Old Jul 18, 2010 | 06:24 PM
thook's Avatar
Hopefully it's something that you've overlooked, but it could be a bad TPS or even an airflow meter.
What motor do you have?
Troubleshooting guide for 3vze....
http://personal.utulsa.edu/~nathan-b...63troubles.pdf
Looking under "engine stall". If you have a 22re, same components apply to the symptom.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
