Information On Trailmaster Lifts Anyone???
Old Feb 15, 2008 | 05:26 PM
yotapwr's Avatar
I need info on trailmaster suspension lifts!!!!
Old Feb 15, 2008 | 05:28 PM
fillsrunner4's Avatar
instead of trailmaster check out trail-gear, Marlin crawler and Allpro offroad, theres also a few other good ones but yeah youll like what you see
Old Feb 15, 2008 | 05:31 PM
yotapwr's Avatar
i bought a 4" lift but it came with no instructions i got the layout of the parts just cant figure out where some go
Old Feb 15, 2008 | 05:32 PM
yotapwr's Avatar
trailmaster^^^^
Old Feb 15, 2008 | 05:41 PM
maybe this will help Tech support for trailmaster if not search the web more for the instructions. that or call them and have them send you some.
One more thing you could do is post a pic or two of parts you need help with and that could help others help you
Old Feb 16, 2008 | 09:39 AM
yotapwr's Avatar
Where do the brackets go, in the picture it is the two up front looks just like the ones that support the crossmember, and also the pair of small brackets between the actual crossmember brackets........? understand
Old Feb 16, 2008 | 09:42 AM
yotapwr's Avatar
basically all 4 90 degree angled brackets and the two "C" frame brackets
Old Feb 17, 2008 | 04:17 AM
91 4Runner's Avatar
Here is as detailed as I can get... I have the same lift hopefully going in soon.... Mine however had no instructions due to getting from a junk yard.
Hope this helps...
Old Feb 18, 2008 | 05:07 AM
yotapwr's Avatar
helps alot, i precitate it ive looked all over the internet for that little bit of info, but never was succesfull.
Old Feb 18, 2008 | 05:17 AM
04 Rocko Taco's Avatar
from what I see here, and everything i have heard before about TRailmaster....is...look elsewhere.
Old Feb 18, 2008 | 10:07 AM
Workhorse's Avatar
I had a Trailmaster lift on my 87 truck it wasn't to bad but definitely had its flaws. (i did some parts trading and got my lift free so i couldn't complain)
A side note when installing the rear cross member you will want to cut a piece of pipe or square box steel that can be used as a spacer so you don't crush the Rear Lower A-Arm drops when tightening the bolts that hold the rear cross member on. If you plan on doing any major wheeling you will want to fab up a heavier cross member for the rear A-Arm drops.
Old Feb 18, 2008 | 10:23 AM
rideocc's Avatar
I have the exact same lift on my 93 4Runner but with the rear coils instead. The front took a little figuring out but the rear was easy. The only trouble I had with the front was one of the camber adjusting bolts was seized in the bushing collar. We ended up having to cut it out with a sawzall then get a new bushing pressed in. I like the lift as I only do mild wheeling and camping with it offroad. I have only aligned it once in a year and it steers great. I agree that if you are going to do more aggressive wheeling, you should beef up the rear crossmember. We also got some larger bolts for the front and rear crossmembers as the there was too much play. If you need help, let me know and I could take some pics. I am up in Edmonton, Canada and it is snowy so I would have to wash it first. Cheers.
Old Feb 20, 2008 | 09:18 AM
yotapwr's Avatar
i preciate it but i will only do minor wheeling for now no rocks or heavy crawling as of yet.
Old Feb 20, 2008 | 10:23 AM
run4her's Avatar
I have that lift no problems yet.
Old Feb 20, 2008 | 06:58 PM
yotapwr's Avatar
I gonna put it on myself, any major modifications i should be aware of?
Old Feb 21, 2008 | 04:33 AM
Workhorse's Avatar
Well it has been quite a while since i installed my lift but from what i remember it was fairly easy i only had to cut one piece on the truck. I believe the pro-comp lift is identical to the trail master.
86-95 Toyota 4WD 4"
http://www.explorerprocomp.com/tech_instructions.php
The lift kit is part # 57089
Direct link to Instructions:
http://www.explorerprocomp.com/PDFs/is/57089.pdf
The part you have to cut is on page 5, Illustration 2. you have to cut one of the lower A-Arm brackets so the front differential will lower onto the new mounts.
The part i spoke of on my previous post is on page 6, Illustration 4. The Pro Comp instructions recommends using short bolts where i just used a spacer and put a long bolt clear through the lower A-Arm mount to hold it tight.
When i got my kit it was missing most of the drop brackets for the Brake lines and the rear equalizer. I just took some steel strapping and made some new ones
I didn't have these instructions when i did my install either but i did it over a weekend easily. Take some pics If you have any problems feel free to PM me.
89fourrunner
Feb 17, 2016 06:52 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
colasurdo
Jul 18, 2015 07:06 AM
