- Toyota Sightings
- Transmission fluid change, and filter questions
- Lock cylinders
- Flat towing a 4runner with a lunchbox locker
- 1985 diesel SR5 AC swap
- 22re very rough idle
- Wrong lubricant in 94' Pickup Automatic Transmission Transfer Case
- Fuel Gauge works intermittently
- Riddle me this...
- VSS issues
- 2nd GEN steering stabilizer
- Rear brake proportioning valve dead? 1987 toyota pickup
- 87 4runner with DIY Popup Camper Rear Suspension Upgrade
- 1994 4x4 pickup automatic transmission slipping? Speed sensor?
- SAS rides rough
- Starter gear replacement
- 1993 4runner 6v auto
- 1986 Pickup, 4wd front bump stop
- 2WD to 4WD (Auto to Manual) Swap - What Parts Do I Need?
- 1992 pickup 22re no start has fuel and spark
- Gnarly shifter hole
- Coolant upon Coolant
- 4x4 Accidentally On
- Is This a Suitable Transmission oil?
- Shattered back window 88 4runner
- 93 3.0 radiator maintenance recommendations?
- Testing an ECM.
- 3vze testing ignition coil?
- Heatshield Armor on 3VZE Crossover Pipe.
- 22re Crack under crankshaft bearing
- stuck bumper bolts
- Crazy Deck Lamp idea - thoughts?
- Not your typical 22re tapping noise!
- 86 22re Throttle Body Confusion!
- Toyota R1FA Transfer Case Question
- Manual 2WD steering box differences for 1986
- 89 pickup code 52
- Rod bearing replacement
- Very slow crank
- 22re idle stays wherever i leave it
- LH85 Toyota Hiace suspension questions (IFS)
- 1993 4wd pickup ome shocks? Part number?
- Replacement power steering pump question
- 1st Gen Clutch/Brake Assembly for Swap
- Starting issues
- Cold Start Injector Voltage
- Ifs control arm and diff relocation bracket.
- Help please!!! Looking for 93 style pickup side graphics passenger side.
- 1989 22re idles fine no power
- Vacuum help
- 1994 toyota pickup front diff. gear ration, with ADD
- 95 4Runner Code 52
- Swapping cabs
- Can't get brake pedal pressure
- Engine seized 92 23re
- Rear Brakes Locking Up
- Help 86 Toyota pickup stuck in neutral
- 1994 4Runner 3.0 Auto Transfer questions, operation and fluid type, does it matter?
- Inclinometer doesn’t light
- 94 manual 22RE revs high and low in neutral
- 1993 4runner 3vze Starts and idles down and then turns off
- Exhaust Pipe Snapped in Half
- Octane rating for 12 to 1 compression ratio 22r?
- Is my timing correct? (Pictures included)
- First gen 4Runner does not start
- 86 4Runner No Power Uphill
- Fsu 88 Toyota 4runner turbo edition
- Why are my RPMs so high while driving?
- 3vze code 42 speedometer stopped working
- 91 Pickup needs work - Any recommendations in upstate NY
- 1986 4Runner help! Crank/run/die/repeat
- 86 sr5 misfire w/lights on
- 86' Pickup bed size comparison???
- Replacement Radiators - Not Plastic
- Black exhaust smoke after rebuild 1993 4runner 3.0
- 1986 or 85 1 ton front bumper needed
- 1990 Toyota pickup bed box exchange
- Spare RH mirror mount cover?
- Why is my gearing so short?
- Wiper solution
- 1986 Mystery Wire
- 1988 3vze running rich, misfiring at idle only.
- '94 Toyota Pickup R150F Leaking Transmission Oil from Breather Port
- Dash lights will not dim
- Rust repair panel/painting/windshield---1986 Toyota Pickup
- Turn signal issues
- Hi I have an 86 pickup won’t turn over
- Wiring Help
- 89 4runner cuts out
- Crank Pulley Faceplate Bolts
- 1987 Truck - Anyone know how to disable the door dinger and keep the dome light
- 22R, 2.4 1995 does not rev above 2500rpms
- 1987 Toyota - Has anyone replaced the chrome trim style windshield with a gasket
- Fixing reverse lights on a 1987 with Auto Transmission - Neutral Safety Switch
- 89 pickup runs bad cold and like a kitten when I leave it run for 20 mins.
- Project: STEEL BEANS on Youtube
- Stumbling 87 4WD Std Pickup, 22R carb engine
- Broken wire..What to do about this?!?
- O-Ring leak?
- multiple sized thermostat options?
- Fuel line brackets missing
- Any 3.0 gurus out there? Throttle bounce issue
- 1st gen 4Runner - anybody else getting pulled over constantly?
- Interior Door Panels
- Help with Auto Transmission
- VSV Part number Help 90910-12085
- Rear wiper motor cover
- Need help identifying vacuum switch.
- Want to change 3" lift back to stock (pic)
- 86 transmission 4th gear out
- 1987 4runner windshield wiper issue
- 4 Wheel Drive Crunchy Noise 86 4Runner
- 3ZVE High Idle
- 12.5v on the NE circuit coming out of the ECU?
- Fuel tank leak
- Aux rear console heater grommet
- Need Help Identifying Mystery Wire
- Need a 2wd pickup hood height measurement please
- Timing maxed out
- 86 22re engine wire harness compatibility
- Windshield Wiper Linkage Grommets
- 22r Carb Fuel Cut Solenoid - WHAT'S IT DO?!?!
- 1994 Pickup: Did I make a mistake??
- Swapping ECU???
- G54 transmission missing bolts??
- Junkyard Trucks Have Missing Parts!
- '86 Pickup Aisan delete - SW FL
- Clutch choices for 35's
- It’s dead, isn’t it?
- Lurch when starting/stopping to give gas
- seat covers
- 1992 22re pickup running issues, please help.
- 1995 3VZE High Idle Surge
- 1986 Toyota W56 transmission issues. Input shaft seal??
- 1994 Toyota Lt
- Spark plug comparison
- Where does this go on the 22re?
- Parking light relay makes whining sound
- '93 Dually Pickup EGR Valve Replacement
- Where to buy igniter?
- Front driveshaft growl
- Need Front Drive Shaft Info Please G or W 92 22RE
- 3.0 1994
- Question about 95 Pickup 2wd transmission crush washer
- New throwout bearing noise after 2 months use
- sensitive steering
- Is mixing transmission fluids advisable?
- Diff swop
- Rear bumper reproduction
- 88 4runner, help to identify engine part.
- Need a complete 3-4" lift kit for my 95 2wd (not Tacoma)
- 88 4R tail gate window regulator parts
- Why is my carb overfilling with gas???
- 22re injector issues
- Mystery Noise from Underside
- 94 3.0 issues
- 89 Pickup OEM door window weatherstrip assembly
- 86 22r 4x4 installed vacuum lines location to finish…
- Marlin Crawler Steel Braid Clutch line on 91 3vze pickup: Will it fit?
- 4WD Not working 1990 4runner
- 4Runner coil to leaf (Chevy 63’s) pics? Tips?
- Battery tray part # for Group 24 battery
- New Roof Rack Kit
- Measuring cam lobes 22R
- 86 22r
- 1988 4Runner 22RE M/T Crank no start
- 89 Toyota pickup won’t warm up
- 92 3vze 3.0 intermittent power cutting out issue
- Rough idle, what am I missing here?
- A/C Compressor misfit for an 88 4R
- Amazon Evergreen head
- 88 Toyota 4x4 pickup 22re 4 cyl non-turbo
- TCROD sound but chain guides ok?
- 22RE Engine
- 86-2x4~22R idles perfect then drops outta nowhere
- 88 Toyota pickup 2wd upper control arm
- 1986 4Runner Junkyard Rescue-Resto
- California Oxygen Sensor
- Gauge cluster swap
- !!!NEED ADVICE 3ZVE accelerates to red line when shifting, stuck throttle !!!
- Recommendation for vendor for a replacement antenna mast?
- Does replacing head gasket require draining/refilling transmission fluid?
- Won't idle - Fuel Cut solenoid? Something else? See video.
- 1986 4Runner - the ol' cold start issue
- 22RE Valve ticking much louder after timing/head work
- 86 2x4 5speed won't ˟˟˟˟ gears while running
- Frame swap
- Ignition Switch wire identification
- Hairline crack intake side cylinder head
- Full time headlights on 1993 4runner
- Needing recommendations for buying a 22re head
- Error 52, won't run
- 84-88 Toyota Pickup Heater core O Ring and half Circle clamps part number
- 3vze started and ran fine, sat for a week, now just cranks
- Is there supposed to be a jet on the power valve?
- R12 A/C schrader valve cores on 88 4R?
- 1986 pickup
- Opening top of engine. Gaskets? Electrical connectors? Replace?
- Bouncing cold start idle…thermostat sticking ??????
- Need help
- Need help
- ‘91 Pickup Braided Rear Brake Lines?
- What do these Connectors hook up to???
- 94 PU 3.0 4X4 Cranks no start.
- Buying grandpa driven low miles '93 ext cab 4x4 - seeking advice
- Rear Driveshaft Install
- Head shaved 20 thou. Now I need a gasket.
- '94 4Runner Brake woes
- Drive shaft question
- 94 pickup weird electrical issue
- 1991 Pickup Inside Door Handle Stuck..
- 22RE Engine Issue - White Smoke from hood - need advice
- 1988 4ruuner V-6 Clutch master cylinder and slave cylinder
- Photos of gear shifter sticks
- 4runner purchase
- Screeching noise when truck running.....sometimes
- Multiple part #’s for 3VZE TPS
- 1988 3vze Fuel Injector Help
- 3nd pickup single cab swap onto 2nd gen 4runner frame
- Disc Brake Rear Conversion Issue
- Headers/ body lift/ auto
- 1988 Toyota truck front fender install
- 3.0L Ticking
- 22re camshaft appearance
- 95 2nd gen auto trans issue
- A/C from 92 to an 87
- Fuel pressure regulator Install ?
- New clutch not releasing
- Brake Lights Only Work When the Truck is Off
- 1986 4Runner Code 4
- 1986 4runner, No start issue
- What the heck is this thingy?
- Door Glass Detached
- Click no start problems
- Radio wiring harness plug
- repair broken clip on interior trim
- Power steering rebuild issues
- OEM manuals on eBay
- 94 4runner 3vze very rough idle, stalling, running rich please help
- Need Help
- Installing New Water Pump
- 87 4Runner No start No CEL
- Questions about putting my truck back together (95 4runner 3.0)
- Raise Truck @ Rear Axle
- Truck bed differences between 1988 and 1989
- 1994 4Runner 3vze power loss
- Front Lower Shock Mounted Broke - Control Arm Replacement?
- 1988 1st gen 4Runner Build (Honey Badger)
- Weber 32/36 vs Stock Carb - Lets settle this...
- 94 body appearance questions
