3vze code 42 speedometer stopped working
Old Mar 19, 2023 | 05:39 PM
mike250's Avatar
my speedometer stopped working and i got code 42. i bench tested the speed sensor with a 6 volt battery and it seems to register on the multimeter. the 12 volts and ground wire coming to the speed sensor works. i stuck my finger in where the speed sensor goes and i think i am able to feel a gear in there and the gear turns with the transmission in gear. is that normal? it doesn't seem like it should be moving freely with the trans in gear.
Old Mar 20, 2023 | 08:59 AM
mike250's Avatar
ok i stuck a pencil in a drill and put it up against the gear on the speed sensor with it plugged in and had someone look at the speedometer in the truck and it moved. i put the speedometer back in the truck and now the speedometer works. does anyone know if speed sensors fail intermittently? do they need to be taken apart and cleaned?
Old Mar 20, 2023 | 09:11 AM
scope103's Avatar
"Intermittent" is how they fail. Someone on this site reported success cleaning one, so it might help.
The sensor has a hall-effect chip; the shaft has a magnet that spins near the chip without touching it. An o-ring keeps transmission oil out of the sensor; if that o-ring fails (particularly if you have metal particles in the oil) that won't help. So if you pull out the shaft, be sure to replace the o-ring as well.
Old Mar 20, 2023 | 11:36 AM
mike250's Avatar
well i didn't see an o ring on the shaft. i did see some rubber thing inside the housing that the shaft slides into. i cleaned everything put in some white lithium grease put it back together and it works so far. hopefully it will continue to work.
Jpl00311
Sep 27, 2022 06:35 AM
redghost.308
Aug 26, 2016 10:01 PM
your-real-dad
Apr 8, 2016 11:21 AM
raptor510
Jul 27, 2013 11:42 AM
BoostinChick
Oct 24, 2012 07:46 AM
