repair broken clip on interior trim
Old Dec 31, 2022 | 08:57 PM
jdfnnl's Avatar
A clip on one of the pillar trim pieces broke when taking it off and am looking for the best method of patching it back. As shown, I already tried sistering a strip of epoxy putty here but it ended up being more brittle than the original plastic. I would like to try the same approach with a different material but looking for guesses as to what may be the best glue considering this failure point. My approach would probably be to put a glob of the substance and carve it into shape when dry.
Old Jan 1, 2023 | 05:23 AM
Melrose 4r's Avatar
5 Year Member
I would first consider if you could use a double sided tape like 3m makes. It’s about .030” thick and you could stack it or glue another piece of plastic on then adhere to that.
Old Jan 1, 2023 | 07:08 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I tried repairing the clips om my A-panel trim. Nothing worked great for me. I ended up installing a small nutsert in the metal and using a trim machine screw to hold the panel in place.
Old Jan 1, 2023 | 07:17 AM
JoeS's Avatar
You could try this. I hear it does work as well as advertised. Build you up a new clip or use to to secure the broken part
https://rtstools.com/repairing-broke...n-cars-bondic/
Sarcazmo
Feb 23, 2014 06:18 PM
JD and Beastlet
7
Apr 28, 2008 10:58 AM
dudedude
Nov 19, 2007 04:55 PM
swerks
Sep 6, 2006 08:10 PM
dajabr
Sep 27, 2004 05:39 PM
