99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 02:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
How does the interior trim for the hatch come off?
Old Apr 24, 2008 | 07:04 AM
JD and Beastlet's Avatar
I'm scoping out a backup camera install for my '05 Sequoia limited. The plastic trim on the inside of the rear hatch will have to be removed to run wires from the camera to the back-up lights, but there are no visible fasteners on the trim piece.
Looking for how-to advice here.
Thanks,
John.
Old Apr 24, 2008 | 09:24 AM
eric-the-red's Avatar
Not sure about a Sequoia but on both my 4Runners it was attached by plastic plug thingies around the edge. I could remove it by carefully prying it off with a screwdriver.
Old Apr 24, 2008 | 09:47 AM
Hey Eric,
Were those plug thingies visible from the outside, or did you have to pry up the edge of the trim to see them?
Cheers.
Old Apr 24, 2008 | 10:50 AM
Originally Posted by JD and Beastlet
Hey Eric,
Cheers.
No, they were completely hidden. They just push into holes in the tailgate sheet metal so prying up the edge usually popped them out.
Old Apr 24, 2008 | 11:48 AM
Sounds like mine, then. Thanks for the tip!
Old Apr 28, 2008 | 02:47 AM
Thanks again for the info, Eric. I used a pry bar against a piece of cardboard to remove it.
I had a lot of the tailgate apart yesterday:
I discovered that the upper and side hatch trim has to be removed in order for the main hatch trim to come off, and the bolt securing the pull strap assembly's gotta come out too.
This is part of the continuing back-up camera install saga, but I'll start a new thread for that.
Old Apr 28, 2008 | 08:15 AM
Good to hear it came off OK. Where are you putting the camera
Old Apr 28, 2008 | 10:58 AM
It's mounted on a flat piece of metal that slips behind the license plate and is secured with double-sided tape:
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
toyotasaurus
Sep 24, 2015 03:30 PM
