Turn signal issues
Old Mar 11, 2023 | 02:31 PM
Rockymt87's Avatar
Turn signal issues
I have a 1990 pickup with the 3.0. I changed all the exterior lights to led and now when I use the turn signals, all 4 blinkers flash as if I turned on the Hazzards. Can't figure out what's going on. Any help?
Old Mar 12, 2023 | 08:58 AM
Jimkola's Avatar
YT Community Team
5 Year Member
It sorta begs the question, if you put the old bulbs back in do the turn signals work properly?
Old Mar 12, 2023 | 09:11 AM
Rockymt87's Avatar
I haven't put the original bulbs back in nor do I have them anymore. The bed is gone and the headlights were changed to led with built in turn signals. I did have to buy a stand alone harness to get the headlights to work properly, is there some sort of connection that has to be made for the turn signals to work. The hazards work fine, just the turn signals act like you turned the hazards on.
Old Mar 12, 2023 | 09:15 AM
SomedayJ's Avatar
Here:
https://www.yotatech.com/forums/f116...issues-254754/
Old Mar 12, 2023 | 10:53 AM
Discombobulated's Avatar
So you took the original turn signals out and now are using the built in signals in the headlight housing and had to get a different harness for the headlights to work? Was the original turn signal wiring tapped into the new headlights? Besides the hyper flash issue if you have it, it sounds like something is crossed, led bulb bad, wiring needs to be looked at etc, very hard to troubleshoot when aftermarket headlights with stand alone harnesses are wired, we have no clue what has been done here…..
I would trace backwards from when they worked and go forward from there.
Old Mar 20, 2023 | 06:43 AM
MatthewSwan's Avatar
Originally Posted by SomedayJ
Here:
Spoiler
Thank you, you made my day. I am also having the same issue.
Rockymt87
Apr 3, 2023 04:06 AM
lmutter
Feb 1, 2016 10:30 PM
JRunner90
Feb 24, 2009 07:10 PM
