Turn signal not working???
Old Nov 12, 2005 | 04:40 PM
JRunner90's Avatar
I tried searching for some info but I couldn't find anything! Well when I turn my turn signals to the left or right they don't work on my 1990 4runner. I've checked all the fuses and they're all good. I also I turned my hazards on the lights blink fine! What else could it be??
Old Nov 12, 2005 | 07:06 PM
4Crawler's Avatar
Could be the turn signal switch itself, dirty contacts inside it. I think the flasher is shared between the turn signal and hazard function, only difference is the path the current takes to the turn signal bulbs.
Old Nov 12, 2005 | 10:07 PM
Elton's Avatar
check the bulbs mine work them self lose i give them a tap and the work fine may need to clean the socket contacts too
Old Nov 13, 2005 | 09:02 AM
JRunner90's Avatar
Alright imma try to clean that out and see if that works!!! Thanks for the info guys!!!
Old Nov 18, 2005 | 10:20 AM
JRunner90's Avatar
Well, I finnaly got it to work! It was the fuse, it wasn't bad though, it just didn't have a good connection! I just twisted the fuses out a little bit so there would be contact and it works great now!
Old Feb 24, 2009 | 07:10 PM
CHIVA's Avatar
Hi i need some help my 95 toyota turn signal and flasher lights not working all fuses ok what can i do.
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
HRDC0R19
Jul 5, 2015 06:43 PM
aciorba23
Jun 29, 2015 04:18 PM
infinityisfive
Jun 16, 2015 06:51 PM
