Wiper solution
Old Mar 14, 2023 | 09:07 PM
Blueman's Avatar
Wiper solution
Does anyone have a solution for how to buy the wiper refill material for a Gen1 4Runner ('87)? The original part went obsolete, but then I found a newer Camry part worked fine, but now that seems obsolete.
Blades used to be available, but are no longer. I used the A450 rather than the A400, which fit and work better. I sit tall in the saddle, so I need that windshield clean right up to the top!
The Camry part is 8521424H90
https://parts.toyota.com/p/Toyota__/...521424H90.html
I just tried to order it, and it was rejected by Toyota.
I'm fearful of j-hook adapters that they'll be janky, and also move the center point of the wiper up higher and I'll lose windshield coverage in the lower areas as a result.
Anyone have a source for the original wiper refills? Or, begrudgingly, a j-hook solution that doesn't move the center-point of the wiper blade?
Old Mar 15, 2023 | 03:09 AM
dbittle's Avatar
I put the J hook adapters on mine last week. They cost about $6, so they’re cheap to try out. The good thing is they let you use better wiper blades.
Old Mar 15, 2023 | 07:36 AM
Jimkola's Avatar
YT Community Team
5 Year Member
You can still get the blade assembly that uses two screws.
the original part number 85212-60030 has been changed to 85220 -YZZ16-TM
I liked it when you could just replace the rubber insert. I found it pretty easy to zip out the old and slide a new one in. But many were challenged and complained. Pity
Old Mar 15, 2023 | 09:18 AM
wallytoo's Avatar
i've been using the adapter-type since i bought the 4runners (2013 and 2018). 16" blades, available at any parts store. summer and winter blades, of course. seem to work well to me.
Old Mar 16, 2023 | 06:37 PM
Genera_lee's Avatar
my truck, a 91, already had the j-hook adapters on there. they work great. i've been eyeing some of those new scrub-blades that have 2 wiper blades in tandem on each arm.
combatcarl
Feb 10, 2014 05:33 AM
Crtzlow
Sep 17, 2012 03:02 PM
DavezFever
Dec 18, 2007 06:55 PM
PirateFins
Nov 12, 2004 06:16 AM
cjrl
Jan 24, 2004 03:13 PM
