Is This a Suitable Transmission oil?
Old Apr 11, 2023 | 09:18 AM
86TurboYota04's Avatar
Been looking for some GL4 gear oil for the R151F in my 4x4 Pickup. Found this at the autozone, claims to be Gl-4
Just curious what the forum's opinion is on this one.
Old Apr 11, 2023 | 10:20 AM
millball's Avatar
Gear oils that meet GL-5 standard are often said to be GL-4 compliant, as this oil says on the label.
Using this gear oil might not harm your tranny, but it is probably not the best choice.
GL-5 spec oils are often found to be too 'slippery' to permit old, worn syncros to function to the best of their ability.
Sta-Lube, Red Line, and others still sell straight GL-4 gear oils.
Where I live, here in the west, I can get 5 gallon pails of Arizona/Colorado Petroleum straight GL-4 gear oil, and that's what I use in my syncromesh trannys.
GL-5 oils are certainly better than GL-4 oils in hypoid gear differentials though, where there is more sliding gear friction than there is in transmissions.
Old Apr 11, 2023 | 10:37 AM
JoeS's Avatar
I'd use the GL rating and weight as specified by Toyota. Then there is no issues nor any need to try to improve Toyota specs. Changing the lube oil on schedule is the key and Valvoline makes a good oil. I change lube oil every 100K miles on my 86 2WD (482K miles) 5-speed and differential. Still original that shifts great with no issues nor leaks.
Old Apr 11, 2023 | 12:09 PM
I've heard good stuff about the Redline oil.
Where do you get your oil from? I live in southern AZ.
Old Apr 11, 2023 | 12:16 PM
millball's Avatar
Arizona Petroleum Company
1015 S Cherry Ave, Tucson, AZ 85719
Rugged 75W-90 EURO >> Straight GL-4 spec gear oil.
Old Apr 12, 2023 | 08:26 PM
Blueman's Avatar
GL-4 only. A higher number isn't better for your tranny (because of synchros). Redline is nice stuff, but basic dino oil is likely just fine as well. Me? It's so rare I'll change it that I'm a Redline kinda guy.
skbrdjk13
May 13, 2021 05:29 AM
94yota05gto
Aug 28, 2008 01:42 PM
JEBSR5
Jan 29, 2007 02:55 PM
rimpainter.com
68
Aug 24, 2004 01:17 AM
FunRunner01
16
Jun 27, 2004 08:04 PM
