California Oxygen Sensor
Old Jan 26, 2023 | 06:51 AM
katsu's Avatar
I've been trying for the past week to track down an oxygen sensor that is compatible with the California 3vze ECU.
RockAuto only has a Walker compatible. All others are Federal only.
Toyota said they don't have any of the OEM 89465-39515, and ToyotaPartsDeal confirmed no stock.
AutoZone, Napa, and O'Reilly all have nothing that is California spec.
The eBayer with 9 of Denso 234-4511 (The CA spec sensor) canceled my order citing no stock (despite listing stock and keeping the listing active after canceling on me)
Denso 234-4052 is Federal spec and will NOT run the truck. I throw a CEL and it won't even start (I repinned the dead sensor's plug onto the 4052).
Are there any other places I may have missed that can source an OEM quality (NTK or Denso) sensor? I'll get the Walker for now (And pray it doesn't get canceled like every other order I've placed), but it's insane that an o2 sensor may be the death knell for my truck.
Old Jan 26, 2023 | 07:53 AM
JoeS's Avatar
Have you tried Amazon as that Denso 234-45111 show some for sale.
Amazon Amazon
Old Jan 26, 2023 | 08:28 AM
katsu's Avatar
https://www.amazon.com/Denso-234-451.../dp/B0018JXF04
I appreciate the link. "Usually ships within 3 to 4 weeks." doesn't breed much confidence, but I'll give it a try!
Old Jan 26, 2023 | 08:31 AM
JoeS's Avatar
Better than nothing. At least with Amazon you can ship it back no problem if it doesn't work.
O'Rielly has one as well.
https://www.oreillyauto.com/detail/c...r/den1/2344511
Old Jan 26, 2023 | 01:47 PM
katsu's Avatar
Unfortunately, the O'Reilly one shows unavailable to order, as it does on Napa and AZ, even when called to attempt to purchase. Gotta hope Amazon comes through in a month.
Old Jan 26, 2023 | 02:20 PM
JoeS's Avatar
Missed that out of stock.
Old Jan 26, 2023 | 02:26 PM
JoeS's Avatar
Missed that "out of stock." Good luck.
Old Jan 27, 2023 | 05:37 AM
Jakespeeds's Avatar
I have a 95 here in California. When I bought it I could not get it to pass. Went to Toyota to get the O2 sensor. They had to order it but it only took a couple of days to get it in stock. But I had no idea there was a California version. First I heard of that.
Jake
Old Jan 27, 2023 | 08:26 AM
JoeS's Avatar
I noticed RockAuto has Califotnia as well as Japan made listed for the 92-93 O2 sensors. Crazy. My 86 is a simple non-heated O2.
Old Jan 29, 2023 | 03:37 AM
katsu's Avatar
Jake
Sadly, Toyota told me they can't get it anymore for mine (93). Do you have one or two sensors in 95?
Old Jan 30, 2023 | 08:40 AM
Andrew Parker's Avatar
Denso OEM O2 Sensor for my 91
Yota Shop might be worth a try?
I ran into the same issue and got (89465-39355 Toyota OEM Genuine SENSOR, OXYGEN) from "partlane" on eBay for $173.
I figured I might have got the last one in existence.
This was over a month ago (Dec 2022).
Old Jan 30, 2023 | 11:20 AM
dbittle's Avatar
Amayama is showing that they have the Toyota sensor for your truck.
Old Jan 31, 2023 | 05:16 AM
Jakespeeds's Avatar
Just one.
Jake
Old Feb 8, 2023 | 08:21 PM
katsu's Avatar
Well, the O2 ended up not being the only problem.
I've got exhaust valve leaks on two of the cylinders, and low compression on all of them. No mechanics in my area are willing to rebuild and I can't handle that job any time soon. So I may have to sell the rolling shell.
Old Feb 9, 2023 | 05:29 AM
Jakespeeds's Avatar
Where are you located?
Jake
Old Feb 9, 2023 | 08:30 AM
katsu's Avatar
I'm in Sacramento (Northern California)
Old Feb 9, 2023 | 08:54 AM
Jakespeeds's Avatar
Hey that is where my 4Runner came from. The Dublin dealership. There has to be someone around there with good used engines for sale. You could get one off of ebay and have it shipped in pretty cheap. I am getting ready to do a 1U swap on mine. Even with 211K it still runs perfectly. I was thinking of popping it out early and making it available cheap. But in thinking about it I am not close enough yet.
Jake
Old Feb 10, 2023 | 07:19 AM
Jimkola's Avatar
YT Community Team
5 Year Member
If the USA sites show the part is discontinued than the Amayama listing will end be cancelled, too.
Discontinued is pretty much the end of the line as far as the Toyota pipeline is concerned.
I've had a hard time finding a Denso 02 sensor for my 1987 22re with cal specs.
Zaffadill
Feb 13, 2020 05:50 PM
michael0584
12
Sep 6, 2011 06:18 PM
prerunning4x4
Sep 12, 2010 03:08 PM
cgeorge
Jul 25, 2008 02:48 PM
grimpy
13
Oct 13, 2005 09:06 PM
