- Vacuum Switching Valve Broke
- Knock sensor
- Am i reading the fault codes right?
- need some advice
- 1993 Toyota pickup 3.0
- need help with the 3vze
- Engine turns over once before starting?
- Dream truck-86 4Runner build
- Removed distributor without setting engine to TDC
- 86 Pickup Lift.
- Blew HG at 140k on '95
- Getting her dialed in
- 92 Pickup no power to AC
- 91 4runner 3.0 Acceleration issues
- Broken bolt, could use some guidance.
- will 89-95 truck fenders "fit" on a 84-88 body?
- Interchangeable parts ???
- Help finding dust cover part
- Battery and brake light always on
- LS/SAS/BJ60/HighSteer - oil pan interference
- Locker unlock brainstorm
- Trouble removing heater fan switch 1994 pickup
- Testing Ignition Control Module with a multimeter
- 1987 4x4 Trailer Reciever
- Parts suppliers
- 4Runner Canopy Questions
- Fuel Pump issue
- complete electrical failure of a '92 Toyota pickup.
- 3vze surging idle issue
- Ecu problem SOS!
- wheels
- Best way to weld toyota sheet metal?
- Question for this electrical connector..
- Loose head bolts 22re
- Loose head bolts 22RE
- Control arm bushing replacement
- 3rd gen pickup transfer case
- 94 pickup 2wd Motor Blown 22re, Important questions Need Knowledgeable people!
- Jetting, Weber for 5,000 ft and up
- Milling the head 22RE
- HELP! Superpooch
- 93 Toyota reg cab. Clutch still losing fluid. Won't crack over.
- Uninstalling lift
- 3vze ps
- 1989 22r: poor idle and backfiring
- DT8000 vs DT3000 on the Front IFS, which shock?
- Noise On Downshift. Video Included.
- How do you remove this lock?
- LED Headlights - List of Truly Plug & Play Options
- 1987 conversion help? 22re to 2L diesel
- 3vze over fueling!!!!!!!
- Bolts on back of 22RE head
- wheel place ripping me off?
- New Build. Tapping noise and oil pressure light. Need Advice.
- Running without injector pintle caps??
- 87 4runner rear suspension
- Wildwood Combination Proportioning Valve
- I wish I knew about this a week ago...
- (22r Carb) Part name ? rough idle/shutting off
- #4 cylinder not firing
- time for an engine swap. opinions wanted!!
- Standard Cab Short Bed 4x2 vs 4x4 Fuel Tank Swap?
- 3VZE intake solutions after 7MGE VAFM
- 1987 22r weber swap throttle linkage problem
- Will timing be off?
- Dashboard Vents
- 1kz-te to 3vze transfer case swap
- 3VZE won't start after knock sensor replacement
- $300 89 4runner?
- HELP. (off topic) could not post under maintenance
- 91 4runner with 96 tacoma axle
- 22r carb throttle linkage pictures needed please
- OEM Rear Bumper Part Number?
- 22re won't start after engine swap
- Help in finding 86 4runner repair manual
- Removing Engine and need some help
- 22RE swap from '94 to '91 body
- 91 Pickup resonator question
- 93 Toyota 4cyl pickup stalling out.
- New Engine Break in. Has Knock.
- 85 efi motor in 86 carb'd truck
- 3VZE Cam Plug Retainer Debacle
- 22RE Stalls After Full Throttle
- Water in oil
- Accurate Engine Temp Indicator With Audible / Beeping Overheat Alert
- 1jz or domestic vortec 4.3, 4.8, 5.3?
- Oil Cooler hose question 3.0 v6
- Catalytic converter. Is it needed?
- Starts and dies...... HELP!!!
- AC vacuum lines HELP
- Efi surging mystery help!!
- Starter cranking with out key.
- Ivan Stewart's 4Runner Pre-Runner - Autoweek
- Fixing the grill.
- Silence is golden. disabling the buzzer.
- Water Temp Sender Location. 88 22RE
- Dash Wiring for accessory & marker light taps.
- Oil Pressure Guage.
- Trailer Wiring.
- Rock Screens
- Dash Removal/Heater Control Repair: Write UP-How to
- Yo yo shaving my head for HPs!? How much?
- Gm alt conversion not charging.. Any info is appreciated!
- How much lift am I rockin?
- 91 Pickup Bed Replacement
- Code 52 intermittent, and other oddities
- 22re pickup overheating
- Can't re-install crossmember
- 22re running rich when warm
- 22re 5 Speed pops out of reverse and sometimes gets stuck
- Auto Trans 86
- New to Toyota
- 300 dollar 4runner. What to do?
- Noise after water intake
- Truck Brakes Dragging
- Camshaft question
- Is my timing chain off by a tooth?
- Gas everywhere, in the intake, coming out the exhaust pipe, in the oil
- 95 4runner rear axle wont center (coils)
- 1987 4Runner manual leaking oil from transfer case
- Need help with oil leak from transfer case area
- Front diff/axle nuts
- Play in driveshaft - and not the u-joints
- help
- Need help!!!
- Hard starting 94 3.0 4x4 pick up
- Knock sensor issues
- All Japanese Classic Meet - Vancouver, Aug. 28
- Head gasket to get locally?
- Alternator Issues
- 22re blown swap 22rec
- Seeking to upgrade stock bumpers--need suggestions
- Efi circuit issues 1989 pickup 3zve
- 3vze timing belt help
- Rear suspension need some help
- 93 Toyota AC blower fan
- Newbie here! 1995 Limited
- Manual transmission: Suddenly no power to wheels
- 1990 wire harness and fuse panel
- Help!! Dropping new motor, oil pan sitting on diff!!
- Is there an A/C unit kit that can be installed onto a 1990 pickup 22RE?
- Replacing My 22RE Engine, What Else Should I Do???
- Installing shifter carrier retainer
- 93 pickup o2 sensor burned due to muffler
- Fuel Pump Issue 94 Toyota Pickup
- Speed sensor issue
- Set timing on 4runner that will not idle
- Side slider window rubber trim and 4runner emblems
- Cam removal and head cleaning
- 86 4 Runner timing chain bent valves?
- Differential size?
- Valve clearance 3VZE
- Trouble with my '86 22RE Turbo (High RPM/Slow roll)
- 3.0 Gear swap
- What is this dimmer switch from?
- Front Hub Bolts and Cone Washers
- 95 4Runner 3.0 starts and stalls
- Gen1 4Runner Matchbox Truck(s)
- Center console
- Extra pipes on the back of a new radiator?
- 88 4Runner tongue weight?
- Head off (w. pix), help me diagnose compression problem
- Removing fan clutch in a 22RE??
- Is Autozone retarded, or am I? (cv boots)
- '86 fender trimming?
- (HELP) How do you remove the Power Steering in a '92 3.0 4R
- AC Condensor Question
- Spongy Brake Pedal. At witts end
- 1990 Toyota Pickup 3VZE A fixing thread
- Black smoke
- Outdoor Car/Truck Cover?
- "Exhausted" From Searching
- 92 Leaf Springs ARB?
- Max tire size for stock pickup 22re 5 speed
- Will the SR5 gauge cluster bolt right on and connect?
- What's a good, affordable all-around shock?
- Anyone try these?
- Epic fails....catastrophic carnage!!
- Which One?
- Worked On The Interior Of The 1986 4Runner!
- 90 v6 pickup no start
- 4Runner in limp mode pls Help
- Missing problem
- A/C Help
- altitude adjustment
- You might be a redneck iiiiif.......
- Suspension question. I bought the wrong shocks. Can I use them as rears?
- SOS - Clutch Problems - 5 speed Swap
- New Front Shock Suggestions after 1.5 Inch Front Ball Joint Spacer Kit
- Rear brake drum cross reference?
- 3vze oil cooler question.
- hole in transmission? (picture)
- Clutch advise
- TG Stinger Bumper for late 85 pickup
- Am i missing part of the throttle?
- Timing kit from rockauto
- 1991 Toyota Pickup 22RE
- 1986 22RE Turbo No Power when in gear
- "New" 1988
- Easily Overlooked Parts for rebuilding 22re and lessons learned...
- Add a leaf for my 89 4Runner
- 4x4 problem
- P195/75 R14 Alternative Sizes
- After market wheel help?
- 1989 pickup crank issue after compression test
- Head resurfacing
- Some random questions about 22RE head gasket replacement
- 95 Yota PKUP speedometer overeading
- Frustrating Oil Pump Leak
- It's back!!! Dreaded Code 71
- Has anyone put a 4x2 Bench seat in a 4x4
- 2.5 rear spring spacer install
- Transmission trouble help please
- Just got a '88 4x4.... let the fun begin
- 2nd gen springs on 3rd gen pickup?
- Horrible mileage 1991 Pickup 4x4 22re
- What makes it hard to put in gear?
- Ovrrheating getting worse overtime
- Very strange cooling/slight overheating situation
- To Paint or not to Paint, the Cab...That IS the Question
- My compression results
- Buying 2nd gen 4Runner
- 1987 steering column u joint replacement
- Installing the timing chain sproket
- front fender and door odity
- Need input/thoughts on project truck!!!
- Rattle between 1500-2000 rpm
- Flamethrowers
- Installed a lce short shifter and now can't put in gear
- 89 4runner 3.0 3VZE engine knock
- Fuel Injectors Won't fit in Holder!
- Mud Guard 88-94
- Carb adjustments
- Need some help
- 86 22r Help needed
- Original OEM Glass Color?
- Bumper Guard for 1992 Truck
- 1st Gen 4Runner - Help with Body Stripes
- Sagging rear
- Looking for 3rd gen 4wd ext cab truck for project
- Windshield Replacement 89 4Runner
- Best Replacement 3vz Power Steering Pump?
- 1991 3vze condenser fan problem
- Resolved: 22RE Intermittent lugging below 2000 rpm
- 88 4Runner keeps blowing clutch masters
- 22r Valve cover breather hose replacement?
- 22rte missing at low rpm and running rich
- 89 3.0 4runner lound tick at idle
- 84-88 pickup front grill on 89-95 pickup
