1987 Toyota pickup
Old Feb 5, 2017 | 12:09 AM
Shadow_Sun's Avatar
1987 Toyota pickup
Hi members. Do any of you know where the crank sensor is located at in a 1987 toyota pickup? I would really appreciated it.
Old Feb 5, 2017 | 12:21 AM
Terrys87's Avatar
To old of a truck for a Crank Sensor. It is set by the Timing Chain and the indicators on the Crank Shaft and Cam Shaft. If I am correct, Crank Sensors are only on distributor less motors. The distributor is set off of the Cam Shaft and is mechanical so no need for a Crank or Camshaft sensor.
Old Feb 5, 2017 | 03:33 AM
wyoming9's Avatar
Red face
Then again the OP may have a 3.4 swap and just failed to give us that information
