front winch bumper
Old Jan 27, 2017 | 06:47 PM
adam38654's Avatar
front winch bumper
Does anyone make an affordable winch bumper anymore? I have checked ebay and craigslist but need to hit the junkyard. I would atleast like a simple push bar for my 93 4runner.
Old Jan 27, 2017 | 07:34 PM
space-junk's Avatar
Scotty can hook you up.
www.addictedoffroad.com
Old Jan 27, 2017 | 09:39 PM
adam38654's Avatar
Or a brush guard that accepts a winch like the old Warn Tans4mer. Does anyone make a simple winch bracket that bolt over the factory bumper ?
Old Jan 27, 2017 | 11:05 PM
toyota88grandsons's Avatar
Scotty will hook u up.(solid)give him a call.shop around,great product.
Old Jan 27, 2017 | 11:11 PM
wyoming9's Avatar
Red face
One can make whatever you desire .
The question is just what do you call affordable ??
Just a guess but I would venture the average is going to be between $600.00 to $1000.00
The more custom it is the more expensive it will be
It is easier to start with the Winch you have and build around that
Will this be a real Winch for recovery or to look impressive on a Tricked out Mall Crawler??
Both are real world applications just the attachment points are quite different.
Old Jan 28, 2017 | 06:02 AM
adam38654's Avatar
$300-400 tops but hopefully half of that. I'm not really looking for a full plate or tube bumper unless used and cheap. I would prefer a brush/push bar with a winch plate or even just a sand alone winch mount.
I want a semi capable winch but I will not be mud bogging or rock crawling. This is just a hunting truck. Some of the logging roads to some areas can get pretty rutted or washed out or I may need help pulling a friends 2wd off of a slick spot. Nothing too serious but not a city slicker looking for cool points.
Old Jan 28, 2017 | 07:30 AM
muddpigg's Avatar
really need to do some research. How you use the rig doesn't change the fact that a winch needs to be mounted solid to frame and capable of support the pulling amount of winch and more. Anything less can lead to damage and injury.
Old Jan 28, 2017 | 01:36 PM
wyoming9's Avatar
Red face
Good luck with that budget !!
You might want to visit all the yards within driving distance and make friends things like bumpers get picked off fast
In your case I would find a local welder draw up what you want built and ask for a price quote .
Old Jan 28, 2017 | 03:32 PM
space-junk's Avatar
Or get a front mounted tow hitch installed. then get a removable winch cradle. can be stored in the cab or the back when not in use.
Old Jan 28, 2017 | 06:48 PM
thefishguy77's Avatar
This ^^^ might be your best option
Old Jan 28, 2017 | 07:19 PM
dropzone's Avatar
Fossilized
This fits your $200 or less budget
trail gear winch plate
http://www.4wheelparts.com/Winches-Winch-Accessories/Trail-Gear-Winch-Mount-Bare-Steel-120116-1-KIT.aspx?t_c=18&t_s=126&t_pt=3440&t_pn=TGI120116-1-KIT&utm_source=google%2cgoogle&utm_medium=cpc%2ccp c&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1& scid=scplpTGI120116-1-KIT&sc_intid=TGI120116-1-KIT&gclid=CjwKEAiAn7HEBRDHwNqitoWqsQcSJAADWmI21f_E VSDleP6xJP36uE31HyINDUfG4D5ZlYcwUuw96hoCcGzw_wcB
mount it and build bumper when you have $$ it is what I based the bumper on my 81 with (see avatar and sig pic)
is a wonderful thing
Old Jan 28, 2017 | 07:48 PM
muddpigg's Avatar
this is what I run. Did re-enforce front cross member. They were a bit cheaper years ago.
Old Jan 29, 2017 | 09:17 AM
adam38654's Avatar
I saw that but It doesnt look like it bolts to the tow hook area, just bumper reinforcement. I would like something like this that can go over the factory bumper. I can weld myself.
Old Jan 29, 2017 | 11:34 AM
dropzone's Avatar
Fossilized
than grab some steel and go to town
Old Jan 29, 2017 | 12:57 PM
wyoming9's Avatar
Red face
I gotta ask if you can weld why even ask if anyone makes a cheap winch bumper ??
Just make what you want and be done.
Old Jan 29, 2017 | 01:56 PM
adam38654's Avatar
I can weld but I don't have much in the way of fab equipment. Just a welder. No cutting torch, plasma cutter, band saw,ect. Just a chop saw and angle grinder. A kit to weld up would be nice.
Like i said I was looking to find a simple push bar, brush guard, or winch mount. I don't really want to replace my factory bumper. I want an add-on.
Old Jan 29, 2017 | 02:05 PM
millball's Avatar
I doubt that anything that would bolt add-on style to the factory bumper mountings would be anywhere near strong enough to be a viable winch mount.
Old Jan 29, 2017 | 02:24 PM
adam38654's Avatar
Push bars bolt under the frame where the tow hooks are and the old Warne Trans4mer brush guard has a winch mount on it.
