PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Rear Disk/Caliper Swap
  2. Need help identifying smashed hose and electrical component
  3. front diff seal help.
  4. Need help identifying smashed hose and electrical component
  5. rear main seal lekaing
  6. No power to door controls
  7. brush guard installation help
  8. fuel injector pigtail?
  9. Can i change my login name?
  10. Where is the dipstick supposed to be?
  11. Call me crazy...idler arm with brass bushing has slop?! huh??
  12. Bench possibility for a 1994 Toyota Pickup. HELP!!!
  13. 86 4x4 carb question
  14. 22R running kinda slugish
  15. Stupid Question
  16. 1994 P/U: Idler Arm & Lift identification question
  17. Chassis greasing adventure
  18. As reed valve question
  19. 1st Gen 4Runner: Extending differential breathers
  20. My Youngest Son's Flatbed Build.....
  21. 3.0 won't stay running with out giving throttle
  22. Need Help - Location of Speed Sensor Pictures Inside
  23. More power=diferente camshaft???
  24. 22RE High idle on start up
  25. Finally got time to tear into my newly acquired 94 !
  26. 1st gen 4runner body replacement parts!
  27. Fuel-Pressure Damper Screw - Loctite?
  28. Help Fixing Broken Speedometer/Odometer
  29. W56 Reverse Idler Gear Replacement
  30. 88' 22RE water pump studs to buy?
  31. 22RE Oil Leak - UPDATE
  32. Starter is shot where do i start
  33. Fuel Line Leak
  34. HIGH Quality Seat Covers for SR5 Seats
  35. Wacky head lights.
  36. Gear questions need help fast!
  37. JDM engine advice and other ramblings
  38. '87 22RE 4runner help: Weird Tranny sound on idle
  39. 22re wont start.
  40. brake resevoir plug
  41. help is needed!
  42. EFI fuse?!?
  43. Need opinion
  44. Rattle noise at 1800-2200 rpms
  45. Oversized Spare Tire & LSP Brake Valve
  46. wiring harness issues on motor change
  47. Help smoking 95 3.slow
  48. 94 4runner with downstream o2 sensor question v6
  49. Matching an engine serial number to VIN on an '87 22R
  50. no heater blower
  51. Headgasket! Help!
  52. BATT./ LACK OF POWER issues
  53. New to me 92 22re with rattle
  54. Rear end clunking?
  55. 86 pickup other mod suggestions
  56. Im I missing something?
  57. Rookie shock questions...please help!
  58. Very rough cold start
  59. Starter, starter releay or switch?
  60. 22re cam
  61. Flushing out the coolant system today, does 22r need to be bled?
  62. She wont hold a charge??
  63. Bought HID headlight help installl
  64. 3VZE leak
  65. Dual battery swap pics
  66. I'll paypal 20$ to anyone who can get my truck started
  67. New 4runner making horrible screeching noise
  68. Header & Muffler upgrade
  69. 1990 4Runner DD, lump of cash, where to start?
  70. 22RTE running lean and smells like fuel..
  71. Tackling the DT Header Install
  72. 22re smog problems
  73. 3vze Block to head Dowel size
  74. Found the cause of my code 52!
  75. "Quality" dealership work?
  76. Post your Pics or ideas "custom front bumpers"
  77. 22re motor swap problems
  78. Rear bumper build
  79. negative battery cable question- where does it go?
  80. Help 22r valves
  81. 1988 3.0 Vacuum Piping diagram
  82. fluid splatter after power steering belt shredded?
  83. TPS unplugged, No CEL
  84. 3VZE AFM Two Digit Code
  85. What kind of tranny/tcase do i need for my 20r
  86. Starts and dies imediately...
  87. what happened here? cause of piston damage
  88. Shift Solenoids
  89. '87 22RTE deck height issue
  90. gearing questions?
  91. Help wanted!
  92. Brake lights stay bright...
  93. Idle question
  94. 1988 22re o2 sensor. Do I need to take the seat out?
  95. Socket size on 4wd 86 Pickup differential drain plug?
  96. VERY hard start
  97. Valve cover mix up
  98. Windshield Install??
  99. Replace Pinion seal
  100. 470,000 1987 Toyota
  101. 87 Pickup heater fan problems
  102. 4runner tach issue
  103. What am I missing?
  104. hicup in my 4runner
  105. sas swap, 96 tacoma 4x4 2.7l
  106. Auto trans shifter loose, '92 pickup 3vze 4x4
  107. 1989 22r - Bizarre cooling issue.
  108. 1987 toyota pickup efi swap
  109. 95 4R Weird stalling and no restart
  110. Post FJ80 spring installation questions....
  111. Question about 88 4wd rear wheel/axle gasket and bearings
  112. Brake Question
  113. shaking toyota 4runner
  114. Turbo-non turbo flywheel clutch kit??
  115. 22re conversion fuel tank options
  116. How many o2 sensors do i need
  117. Dash lights, tail lights, interior lights not working HELP PLEASE!
  118. 90' 4runner hard to start when cold, acceleration is really slow
  119. Drivers side floorboard leak in 88 4wd pickup
  120. mounting a 94 Under body spare-tire carrier onto a 91 4runner...
  121. truck refuses to go into 4th
  122. Ruff Idle
  123. 1990 v6 pickup running rough on hot starts.
  124. Tires, Gears, MPG?
  125. Hard starting 3vz help
  126. Advice need: fix, part out, sell?
  127. 3.0 vz-e hesitation, Idle Mix Screw, AFM
  128. Replacement parts for the R150F transmission.
  129. Clicking sound from front wheel
  130. So I changed my spark plugs...
  131. exploded clutch...
  132. 1993 hoods hard to open
  133. CV hitting
  134. Wrong midplate and jammed stick bushing?
  135. Tailgate Cover
  136. Stanprophets Beater 89 Build
  137. 1994 22re 4runner, Heater Core blew
  138. IFS or SFA
  139. front shocks keep getting mangled by chasis bumpstop
  140. 22RE runs fine when cold or totally warmed up, but terrible during warmup - help
  141. 1989 4runner v6 no start
  142. Major Pinging/Detonation 22RE
  143. Anybody recognize this seat?
  144. Cannot read codes
  145. 1992 3vze oxygen sensor install
  146. how to check for vacuum leaks?
  147. Code 51 issue in 3.0
  148. 89 pickup with excessive fuel smoke
  149. Engine "ping"
  150. stalling when put into gear
  151. AC Condenser Mounting bracket help
  152. Code 22 and 51
  153. Miss in high gear and tick
  154. 4 low slow to engage untill 2500 rpms
  155. How to apply 12V To a Relay?
  156. Another "gear" thread. . .
  157. 88 Toyota pickup
  158. Reverse polarity problem 1992 sr5 4runner
  159. 22re has gas and spark but won't fire
  160. Smoother ride ifs
  161. Cluster just broke!
  162. Softer Ride and a little more travel?
  163. More work on my 4runner....
  164. Fuel Guage Not Working, Fixed, and then broke again!
  165. 88 2wd pickup tranny gears
  166. Truck starts and runs for couple seconds and then shuts off?
  167. rust removal around key hole questions
  168. Con rod bearing identification help please
  169. A340F info
  170. Weird idle on 94 toyota pick up.
  171. HELP acceleration issue, lack of power
  172. Finally painted the rig! OD green. Write-up with pics!
  173. Idler arm help
  174. 95 toyota 4runner steering problems
  175. Is CSI supposed to have a gasket between intake manifold????
  176. insane rear vibration
  177. Check Engine Light Troubles
  178. tranny or release bearing?
  179. Looking for new wheels..... :)
  180. throttle cable 22r
  181. 86 4runner packages(options)
  182. 4th gen 4runner OME suspension!
  183. 94 4runner ADD and cv axle
  184. New member question on 22re head gasket
  185. clock& radio goes out when started and shifting problems
  186. Painted the 4runner
  187. 2 1/2 inch body lift info
  188. 87 yota pickup 4x4 slight knock help
  189. loud squeal after timing chain replacement
  190. Wiper motor/linkage problem
  191. Ignition wiring diagram?
  192. 22re shifting problems
  193. help! am i being ripped off?
  194. 87 22r Rear Wiring Harness
  195. One Ton 4runner brakes
  196. Help! Hose on bottom of charcoal canister?
  197. Throw out bearing issue
  198. 22RE + Pace Setter Header = 02 sensor fault?
  199. how can i tell ? head gasket leak
  200. Rear axle leaking
  201. After replacing O2 senor & TPS
  202. 22RE Head gasket failure due to rust. Learn from my mistake
  203. Can you swap a 1GRFE into a 94 4runner?
  204. 1992 22re vs 1986 22re
  205. Anybody Used/Like Alldata for Repair Manuals
  206. Zuk Mod Questions
  207. v6 3.0 swap to 22re
  208. 22re rod bearings?
  209. Throttle linkage binding
  210. 86 4runner start/ run help please
  211. 92 pu 22RE stalls under load and full throttle
  212. 22re running rich and stuttering
  213. Shifting problems
  214. 22RE cylinder head concerns : on used engine
  215. Intake, exhaust help! 1994 SR5. (Magna flow, Cold air, Manifolds)
  216. couple questions about removing 3vze from tranny
  217. Truck got some long awaited goodys!
  218. Bought an '89 pickup... Couple of questions
  219. mayday yota down. HELP!!!
  220. VAFM swap - Done!
  221. locking hub problem
  222. smittybilt bumper ?
  223. fan question ?
  224. 1986 22r Intermittent Hard Start, Turns Over, Ignition Related.
  225. Need help on clutch! (ASAP)
  226. 1987 2WD Toyota pickup not running (carb?)
  227. 3.slow cuts out
  228. what model do I have
  229. 22RE Noise/Oil Leak
  230. Engine sputter issue when accelerating
  231. cold start valve 3.0 v6
  232. 95 toy pickup 2wd to 4wd help?
  233. ADD to manual hubs question?
  234. Gas tank/fuel lines question...
  235. Alt. died, replaced, now no start
  236. 94' 3V 4x4 power steering underpowered?
  237. 1998 corolla seats
  238. Transfer case crossmember mounting threads stripped out
  239. 88 Toyota pickup
  240. 60/40 bench required
  241. Need advise on trailer towing
  242. Blower motor on low
  243. Tailgate questions
  244. Truck turns to the left when brakes are applied
  245. New engine? or dig into my 3.0?
  246. Pcv valve replacement
  247. Tacoma Rims on a '93?: Also, Shank Lug or Acorn?
  248. Help name this seal!?!
  249. Rear Wheel Well
  250. Oil Leak
