22re motor swap problems
Old Mar 12, 2013 | 06:02 PM
vamped400's Avatar
Hey guys new here. I bought a 95 yota and it needed way more work then I thought. I traded the plow that was on it for another toyota pickup that was swamped and left so i swapped motors. The other truck is a 95 as well. When the other motor was in the swamped one, the fuel pump and all the lights would come on. Now that I swapped the other motor into it the fuel pump seems to not be working at all. is there anything I could have messed up on the swap? or could the fuel pump just mysteriously fail during the swap? any help would be great! thanks
Old Mar 12, 2013 | 06:11 PM
gofar22r's Avatar
Check your plugs by the computer didn't have them plugged in all the way before same prob
Old Mar 15, 2013 | 06:15 PM
vamped400's Avatar
Alright i got the fuel pump figured out, i didnt know the fuel pumps on the yotas didnt turn on until you turned them over. Now another problem. I fire up the motor, it starts and high revs bad for about 10 seconds and then shuts off. I checked all the vacuum hoses and put in a new intake gasket. Any ideas on what it could be?
Old Mar 15, 2013 | 06:16 PM
vamped400's Avatar
I also had the distributor off and i also had the timing chain cover off if that makes a difference. All the lines are hooked up but all of the belts are off right now
vasinvictor
Jan 20, 2016 12:39 PM
jennygirl
Nov 17, 2015 11:24 AM
noahstancik
Jul 10, 2015 11:18 AM
infinityisfive
Jun 16, 2015 06:51 PM
Fred Anarat
12
Aug 27, 2002 04:50 PM
