Help smoking 95 3.slow
Old Mar 15, 2013 | 08:39 AM
95 4runnerv6's Avatar
My 95 4runner v6 when started cold smokes alot from the exhaust. Once it warms up it doesn't smoke at all just when it's started cold. Does anyone know of this is normal.
Old Mar 15, 2013 | 08:47 AM
BamaYota1's Avatar
How cold is it outside, and what cot smoke? What's it smell like?
Old Mar 15, 2013 | 09:02 AM
It's white smoke and its are 30 degrees. It doesn't smell much and my oil is fine I'm jot losing oil and my radiator Fluid is perfectt
Old Mar 15, 2013 | 09:10 AM
scope103's Avatar
Combustion products are CO2 and water; when the exhaust pipes and air are cold the water will condense out as mist. Once the exhaust pipes warm up the exhaust exits warm enough that it will not condense. So some white "smoke" is normal on startup; it shouldn't smell like anything, and if you put your hand in it, it will feel wet (duh!), not oily.
But "some" and "a lot" are not the same. You could be oozing some coolant into the intake or the engine itself, which comes out the exhaust. This will probably smell like coolant. Your leak might seal up when the engine is warm, so that you lose very little coolant. It will not improve with time, though.
Old Mar 15, 2013 | 09:42 AM
BamaYota1's Avatar
If the temp is low outside, the cold start system will be functioning as well. The exhaust itself is a little bit hotter when csi is working, causing more condensation than normal. I am assuming that when cold you have the higher rpm? When the Rpms drop to normal, is the smoke all but gone? Smoke smell a little like gas, but definitely not coolant or oil?
I drove myself crazy the first couple times I noticed my truck doing this ad well.
Old Mar 15, 2013 | 10:35 AM
Ya rpms start high but as it warms they drop to 80p rpms and smoke stops.
Old Mar 15, 2013 | 01:11 PM
When warm they drop to 800 rpms and smoke stops.
Old Mar 15, 2013 | 01:25 PM
BamaYota1's Avatar
Normal. Don't worry about it.
Old Mar 15, 2013 | 06:22 PM
Thanks everyone.
puddlepirate
Jul 30, 2016 06:29 PM
Yotav6power
16
Mar 4, 2016 07:45 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
dzldust
7
Oct 6, 2015 05:39 AM
charlie_fong
Sep 27, 2015 10:06 PM
