22RTE running lean and smells like fuel..
Old Mar 13, 2013 | 10:32 AM
speedfreak's Avatar
Hey there,
I have been having and issue with my 86 turbo pickup. I have two problems that are hopefully related. The first is that the sparkplugs do not look as rich as they should. I have a narrow band 02 gauge that also is showing leaner than it used to. The second problem is that I can smell fuel under boost. it smells strong, like raw unburned fuel in the cab. This would lead me to believe that the cold start injector is leaking, but I can't see any sign of that. I also pulled out the charcoal canister and plugged the lines, but it still smells like fuel. I don't have any exhaust leaks before the 02 sensor either. I don't understand how it can smell so much like fuel, but running lean, unless it is leaking out somehow. I pinched the fuel return line to build up pressure also, but saw no signs of leakage or smell. Any ideas would be greatly appreciated. Thanks!
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
