Clicking sound from front wheel
Old Mar 8, 2013 | 06:10 PM
Weston_Duyck's Avatar
I have an 86 runner and a couple weeks ago a clicking sound started that gets loud above 40mph. I just replaced the wheel bearing and checked everything. It seemed to check out. The sound is still there, any suggestions?
Old Mar 8, 2013 | 07:07 PM
Jagger_MeisterJE's Avatar
Its got the manual hubs right? Rare for them to click, but you may have possibly missed a piece putting it back together or they are worn out.
Old Mar 9, 2013 | 08:21 AM
RJR's Avatar
RJR
Assuming manual hubs, lock the hubs and get it up to speed in 2wd. If the click goes away, it's a good indication that the hub isn't disengaging fully in the free position, and the splines are occasionally contacting. The hub is pretty easy to rebuild; lots of info on this forum if you do a search.
Old Mar 9, 2013 | 08:49 AM
I already locked in the hubs and drove in 2wd. Still clicked
Old Mar 9, 2013 | 09:03 AM
RJR's Avatar
RJR
Not all that much up front to click. Here are a couple of other possiblilties I can think of:
- something in the brakes; a loose caliper or loose anti-rattle clip
- bad wheel bearing - could be the side you didn't work on. I often have a hard time hearing which side a noise is really coming from.
- bad cv joint in combination with a hub that isn't unlocking so the cv axle rotates all the time.
Old Mar 9, 2013 | 09:36 AM
vanduzerwilliam's Avatar
Are you sure it's coming from the wheel, check your front u joint
Old Mar 9, 2013 | 12:24 PM
I just checked out the hub again and it's fine. I did see I have a torn cv boot so the joint might ˟˟˟˟ but the axle shouldn't even be spinning if the hub is unlocked correct?
Old Mar 9, 2013 | 12:48 PM
SHINE RUNNER's Avatar
right the axle shouldn't move if the hub is unlocked. mine was a worn out hub it did the samething i had a spare and changed it. clicking gone
Old Mar 9, 2013 | 12:51 PM
Alright well maybe as another trouble shoot I'll swap the hubs and see of the sound goes to the other side.
Old Mar 9, 2013 | 03:12 PM
87blackbeauty's Avatar
If your CV gets bad enough it will make sounds. I had a ripped boot for nearly 2 years but eventually it started clicking even when the CV shaft wasn't/should not have been rotating. So lock your hubs, engage four high or low, and drive around, turning a lot. If the CV's bind, which would be obvious, time for rebuild/replacement.
Old Mar 16, 2013 | 01:07 PM
did you get it fixed.i wasn't thinking about the cv . mine was solid axle when it happened
Jun 1, 2021 01:51 PM
razorman8669
Jul 12, 2015 12:13 PM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
