Shifting problems
Old Mar 3, 2013 | 11:02 AM
Ringalls523's Avatar
Shifting problems
I got stuck the other day and ever since my truck has been close to impossible to put into gear. With the clutch to the floor if I try to put it in gear it makes a slight grind and I have to force it. Just replaced the slave cylinder and it didn't seem to help. Any ideas anyone?
Old Mar 3, 2013 | 11:47 AM
NorthIdahoyota's Avatar
Can you have someone watch the clutch fork while you push the pedal? Is the master cyl still full?I don't know enough about the guts of the tranny itself
Old Mar 3, 2013 | 01:16 PM
DJ99's Avatar
Check to see if your clutch pedal bracket isn't cracked or broken.
Old Mar 5, 2013 | 07:11 PM
Got it all figured out, thanks for the ideas
Old Mar 5, 2013 | 07:54 PM
Co_94_PU's Avatar
Somebody moved your seat back on you?
Old Mar 5, 2013 | 07:57 PM
My seat stays all the way back. I'm 6'1" and drive a single cab
Old Mar 5, 2013 | 08:18 PM
Co_94_PU's Avatar
Sorry, subtle hinting failed. What was the problem, for whoever shows up later asking the same stuff
Old Mar 5, 2013 | 08:29 PM
Grego92's Avatar
Were you pushing in the brake pedal thinking it was the clutch pedal?
No lie, that was the problem I came across when I saw this girl stressing out in the campus parking lot many many years ago. She was nearly starting to cry because she was going to be late for a new job she had just started. I asked if I could help, got into her 240sx (or something like that) and started it right up!
Old Mar 5, 2013 | 08:39 PM
The guy that sold it to me had a new clutch put in, whoever did it didn't tighten the bell housing bolts and the bottom ones eventually fell out causing the tranny to separate a little bit. All better now
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
