3VZE AFM Two Digit Code
Old Mar 12, 2013 | 09:59 AM
Markarino's Avatar
Hey guys, just running into a small issue regarding the AFM. Some of you should know about the Idle mixture adjustment screw and how it shouldn't be touched. Well unfortunately mine has been tampered with, it should be a easy fix finding the stamped number on the AFM but my doesn't have any number what so ever. I've scrubbed with carb cleaner for a good 20 minutes so i'm pretty sure the number isn't there.
I've gotten all this info off this post.
https://www.yotatech.com/forums/f116...-screw-233016/
My question is could somebody check their 3vze for the stamped numbers? I'm assuming all 3VZE's are the same but just incase mine is a 94 spec.
Thanks,
Old Mar 12, 2013 | 11:02 AM
ksti's Avatar
By the looks of the pic, the top looks like it's been removed and re-sealed, probably someone messed with it.
factory part # 22250-65010
197100-2920
This should be right # unless someone else corrects me.
Good luck
Old Mar 12, 2013 | 11:11 AM
Markarino's Avatar
197100-2920
Good luck
Thanks for the reply but I am well aware it's been tampered with, I do not need to purchase a new AFM cause it can be adjusted back to OEM. There is suppose to be a number close to the screw stating how deep the screw needs to be. I'm assuming mine has been scratched off which is why I'm asking if somebody knows the code that is suppose to be there.
Old Mar 12, 2013 | 11:35 AM
ksti's Avatar
Ok,
Lets try again
looks like there can be 3 different #s
Casting #/ Distance from top of casting to top of screw
30/13.0 mm
26/12.6 mm
24/12.4 mm
mtb_taco
Oct 5, 2015 04:36 PM
crashburnoveride
Aug 28, 2015 09:20 PM
raptor510
Aug 19, 2015 02:15 PM
Sidherish
Aug 2, 2015 01:42 PM
smiley52
Jul 11, 2015 05:16 AM
