88 Toyota pickup
Old Mar 7, 2013 | 05:05 AM
abatter24's Avatar
88 Toyota pickup
I have a 88 Toyota pickup that seems like it misfires when it gets to running temp and I've replaced the plugs and plug wires and it still does it. I also ran seafoam threw it and it didn't stop it so please lemme know some suggestions! Thanks.
Old Mar 7, 2013 | 11:34 AM
Gamefreakgc's Avatar
Grab yourself a multimeter and test the Engine Coolant Temp (ECT) Sensor and the Throttle Position Sensor (TPS) per the Factory Service Manual. These are the most common culprits for poor idle when the engine is warm. You might also want to check for vacuum leaks by spraying carb cleaner at the connections of all the gaskets and vacuum hoses. Any change in idle indicates a leak.
Old Mar 7, 2013 | 12:17 PM
abatter24's Avatar
Alright thanks ill try that
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
