Strange Noise
Old Feb 28, 2013 | 04:41 PM
737IP's Avatar
Strange Noise
94 Toyota truck, 4WD, 3.0 engine. The engine makes a grunting noise when I let off the gas. It is coming from the passenger side near the valve cover. Any ideas?
Thanks for the help.
Old Feb 28, 2013 | 04:44 PM
Inferno451's Avatar
It's probably a sigh of relief, especially it it's high mileage.
Old Feb 28, 2013 | 05:02 PM
737IP's Avatar
Yep. Could be. 206,000 miles.
Old Feb 28, 2013 | 06:08 PM
stanprophet's Avatar
Is the PCV valve anywhere near that VC?
Old Feb 28, 2013 | 06:41 PM
737IP's Avatar
Im not sure. I will have to look. That is a good idea though.
Old Feb 28, 2013 | 06:53 PM
Im not really familiar with the layout of that engine, It has been many years since I have worked on one.
I have heard many PCV valve's make some strange noises.
Hey it is a quick easy check!
Old Feb 28, 2013 | 07:32 PM
Xeo's Avatar
Xeo
Yea the pcv is on the passenger side valve cover, thing is the whole plenum has to come off to get to it.
Old Mar 1, 2013 | 08:09 AM
Gamefreakgc's Avatar
This was just posted about the PCV valve: https://www.yotatech.com/forums/f116...cement-266038/. Not worth your time.
I've never heard one "grunt". They usually rattle or hiss if the plastic is leaking.
Old engines make weird noises. Took me a while to get used to them on my truck with 280k miles, until I realized that it's not hurting anything and runs just fine.
Old Mar 1, 2013 | 08:28 AM
scope103's Avatar
I'd say it's the PAIR valve (80% certain, but worth a look). The sheet-metal cover is held on with four Phillips-head 5mm screws, and at exactly 206,000 miles one or more will get loose. Then the cover vibrates. Usually a "buzzing" sound, but your truck might be tuned to a different key.
Hard to get to in the best of circumstances, but you might be able to do it with a stubby screwdriver (or maybe a Phillips bit in a 1/4" ratchet). If you need to replace a screw (they don't hang around for long once they get loose), consider using a hex-head bolt. Much easier to reach.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
