PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 [247] 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Crankshaft seal replacement on a 3.0
  2. brainstorming "brush wire" mounts
  3. Gas smells
  4. Loud Clang!!!
  5. SAS, BL, Coil to Leaf Conversion
  6. Frames the Same
  7. CE Flashes - No Ignition Reference Signal
  8. fj 80 coil springs and bj spacers
  9. not a front axle? Any ideas?
  10. Another 3.4 swap, Downey header fit...
  11. Power steering gone
  12. tow capacity of a 92 3.0
  13. 86 Tranny Fluid
  14. Brake Pads?
  15. Where to get a tranny rebuilt?
  16. Clutch Adjust revisited
  17. Synthetic oil for break-in?
  18. Muffler mounting?
  19. Anybody runnin' Warn bumpers?
  20. Oil leaking from exhaust pipe
  21. pre-buildup questions
  22. Catalyst and RPM question
  23. what shocks to run in the rear w/ lc coils
  24. Igniter needed.87 4-runner
  25. Are any Yota pickup doors interchangeable with 1st gen 4Runner doors?
  26. Mechanical Fan Bearing PROBLEMS
  27. Bad starter/flooding???
  28. Knock sensors
  29. fuel return
  30. Gear question
  31. Thinking about changing my Air intake location
  32. i snappedthe mystery bolt under the timingchain
  33. oil pressure problem
  34. Another Tranny Question
  35. oil leak?
  36. I need a speed sensor-suggestions?
  37. My 3vze head gasket finally blew
  38. 1992 toyota 4wd after rebuild problems
  39. 22re oil pump
  40. 22re Engine trouble
  41. Engine Problem
  42. Did i brake the hub?
  43. Solid Axle in front
  44. Bumpers: Swap between 88 'runner and 88 truck?
  45. swaybar disconnects
  46. combining 2 leaf packs into 1
  47. Wheel bearings?
  48. 3.0 oil leak....
  49. taking off under coat
  50. Bad Clutch Install?!?
  51. Best place to get OME steering stab?
  52. Is "Arram" a aftermarket throttlebody?
  53. rear chunk swap
  54. CV Shaft problems
  55. Hard to Shift
  56. After a long wait, my parts have come in
  57. spare tire removal
  58. Does anyone do the 4.3L Chevy swap anymore?
  59. Brakes on my 88 Toy
  60. Looking for this Bumper/Valance
  61. Help for daughter's 2WD
  62. Front Mud Flaps for '94 4Runner
  63. 3rd gen truck wiring question
  64. Cold start injector cutoff temp on 3.0?
  65. Aftermarket cruise control.
  66. Seats for a 1st Gen?
  67. What are common issues w/ 4Runners?
  68. Anyone had this problem before? CV Shaft
  69. WooHoo!!!
  70. Selling the Runner
  71. So My Pre-Cat O2 Sensor Is MIA...
  72. where is steering knuckle screw plug?
  73. turbo motor
  74. Tell me what you think about my plans for my Toy!
  75. on-road comfort/handling (SA vs: IFS)
  76. timing, valve, or fuel problem?
  77. The Most You've Towed with a 3.0
  78. AAD wiring for my 5-speed swap
  79. Mexico Build up!! Need suggestions on preping a 92 4-Runner for 4000 mi trips.
  80. A340-H Accumulator Spring Help!
  81. Power Mirrors are not working
  82. Stalling problems on incline, non-carbed
  83. Problems w/ E-brake handle retracting..
  84. Not getting fuel when starting?
  85. oil level question
  86. tacoma rims fit??
  87. Why is my truck killing alternators?
  88. busted a sway link on rear axle (pix)
  89. dose anyone have this clutch?
  90. Coil spring spacer price difference
  91. Northwest Off-Road Quality
  92. Automatic to 5 speed conversion issue-electronics
  93. Bad vibration in front? Please help
  94. Spool install
  95. Question Alternator Related?
  96. broken injector clips
  97. 3VZE - Runs HOT after re-built heads installed
  98. Behind the grill
  99. Mounting gauges in a gen3 truck/gen2 runner?
  100. What Octane do you use most of the time?
  101. What broke?(Lots of Pics)
  102. Mounting aftermarket oil pressure gauge
  103. Weird Dipstick Reading....VERY Weird.
  104. Engine Swap Questions
  105. crossover to cat pipe fun
  106. What kind of shocks do you suggest?
  107. No power to A/C conpressor
  108. 90 4runner engine and wheel advice?
  109. 91 4Runner 3.0. Need help
  110. Painless Wiring Hot Shot starter relay/bump start kit
  111. Cig Lighter Fuse Location?
  112. Power problem with my 94 v6 3.0l
  113. Broken Sway Bar End Links
  114. my 3vze is smoking
  115. Best Place For Plexiglass (4rnr tlgt wndw)
  116. Proof that I suck: 95 4Runner Performance
  117. 3vze weird noise
  118. A little HELP!!!
  119. Mounting 2 new tires up front or rear??
  120. Radiator pictures and question
  121. Blower resistor questions:
  122. Can I drive without my front diff in place?
  123. clutch problem
  124. Rear Main Seal
  125. 1992 22re clutch slipping after rebuild HELP!!!!!
  126. Ideas on gauge placement
  127. Auto tranny stuck in 2nd or 3rd
  128. Shimming The Valves In A 3.0
  129. Pulling A Triler 6x8
  130. if you ever break a snap clip...
  131. 88 Truck 22re 5spd 33 bfg mt's needs gears
  132. Rear Leaf Spring Front Eye Bolt Size?
  133. Oh NOOOOO!!, not #5!
  134. Your experiences with NAPA reman alternators
  135. Can A 3.0 be made fast
  136. 3.0 electric fan question.
  137. FILTHY fuel injectors
  138. cylinder block cleaning
  139. 86 show truck air bag question
  140. Links to V8 conversion info...
  141. DIY Bed cap?
  142. Leaky gas tank solutions
  143. 95 4runner starting prob
  144. 89 automatic body lift question
  145. Where to get header gaskets for the 3VZE?
  146. 3.0 mystery hesitation, backfiring, sputtering etc...
  147. Fuel
  148. 89 toyota 22re idle loping
  149. C-Clip Size?
  150. Starting in the rain
  151. My 3vze intake (in progress)
  152. Need ac belt pully
  153. Changing crank seal
  154. 1994 pickup getting stuck in 4wd?
  155. Smittybilt bumpers
  156. Differential play
  157. Scratchy reverse
  158. New FJ Steelies on 91 4Runner
  159. Brush Guard Bumper Question
  160. Head Bolts 22RE
  161. 87 4runner 22-RE idle problem
  162. good deal to be had?
  163. Nissan VQ35HR engine swap
  164. what color PAINT?
  165. Looking for a decent and cheap tach.
  166. Will I Need A Longer Driveshaft?
  167. No timing belt marks
  168. brake hub question
  169. 4wd help
  170. 2inch driver side lean?
  171. warn powerplant dual force winch
  172. what about Rads?
  173. 87 4runner' Rear wheel leaking gear oil
  174. Hydraulic winch
  175. 4YEC Engine Problem
  176. Porche CVs
  177. What size/style u-bolts for my 4runner
  178. Installing aftermarket eng temp gauge on 3.0.
  179. Front hitch mount for winch?
  180. Damage to Shocks
  181. T-100 CV's in a lifted Runner?
  182. stabilizer bar cushion
  183. Total choas with BJ spacers?
  184. Questions about noises? 95 4runner
  185. Starting Issues
  186. cold start idling issue
  187. to sell or not to sell??
  188. 94 4 runner - no spark problem
  189. 4Runner A/C Fuses
  190. New engine installed and now its dying and overheating!
  191. The quench on my 22R does not look good...
  192. cv axle questions
  193. Has anyone done a 4.0 w/ auto trans conversion?
  194. Jasper engine owners check in!! Also, Orient guys as well!!
  195. 92 3VZE Cold Start Inj. Timing Switch
  196. What is this drip?
  197. 94 4Runner problems in Reverse
  198. 3VZE oil cooler is $474
  199. Should I cut the bumper holder away?
  200. Taking out my side windows?
  201. 92 Truck Cold start/timing chain
  202. Need to know firing order on the 3.0
  203. What's the diff between 4x4 and 2wd truck frames?
  204. '95 4runner build up advice re sliders, cargo racks, etc
  205. What is best 3rd member for 95 4runner
  206. 3vze bored throttle body, who does the best job
  207. A different kind of leaf swap question
  208. Twin Stick for Xcase
  209. 86 4x4 2LT
  210. 4runner missing then died won't start
  211. Anyone ever run duals on the 3.0?
  212. 3.0 engine mount and starter question.
  213. Need a pic of truck with bj spacers and 33's
  214. 3VZ what are they and where do they go?
  215. 3VZE Timing Belt Kit Suggestions
  216. My rig
  217. Truck won't Start!
  218. 3.4 swap now?
  219. Tires???
  220. Power Steering and Idle Troubleshooting
  221. EGR Delete? Any available?
  222. 87 4runner 22re will not fire on second cylinder
  223. Will this 93 cd/cassette player fit in a 95 Runner?
  224. Injector Grommet... which is the right part?
  225. Priming new engine
  226. Possible rebuild on a 22re???'s
  227. my runner caught on fire!!!
  228. testing cold start and injectors
  229. Solo Bleeders -- Earl's vs. Speed Bleeders
  230. demello bumper on 2nd gen?
  231. PAIR Reed Valve operation??
  232. Fk-35 Help!!
  233. suspension questions
  234. a/c fuse keeps blowing on my 88 3.0
  235. 86 ticking when warms up
  236. weird E brake problem
  237. Is there a 4wd light?
  238. 22RE valve train oil problems
  239. Torsion Bars to stiff?
  240. WHY IS THE 3vze so bad to some
  241. Toughin' Up IFS 88 T4R
  242. Pros vz cons of marlin 1" wheel spacers
  243. Removing The 22RE
  244. AC Blower not working on low speeds??
  245. A new 90-95 rear bumper option (4runner) Irbis
  246. Extended Driveshaft Needed Or Not?
  247. Identify a replacement part & earn $
  248. I want better MPG
  249. Coolant Choices
  250. tps adjustment
