3VZ what are they and where do they go?
I have 2 brackets taht I Can not for the life of me remember where they go.
I have scoured the FSM, my Chiltons manual, and looked around Yota tech.
I have this bracket:
and this bracket:
Can anybody show me a pic or a diagram of where they go???
Thanks!
and this bracket:
Thanks!
i will get you some pics of them from my engine bay in the morning...i believe the first one is somewhere close to the powersteering pump, and the second one for sure goes on the outside of the ac compressor
The first bracket is one of the two brackets that support the PS pump. It is oriented the correct way in the first picture and sandwiches on top of the fan pulley bracket.
The second bracket runs from the AC compressor to the PS bracket in the first photo. The end that isn't threaded is held on with the longest of the four AC compressor bolts and uses the forward most bottom hole. The way you have it oriented in the first photo is the correct way. A bolt will go through the first PS bracket and thread into your second PS-to-AC bracket.
You'll know you have it all oriented correctly when it all falls into place. Good luck.
Ganoid's photos show a different AC-to-PS bracket. Your bracket bolts up to the same spot on the PS bracket, except the bolt it uses on the AC compressor mount is the forward lower one.
matmattmatthew
10
02-09-2021 04:15 PM
D.B.T. 87 4x4
07-20-2015 04:51 PM
