Did i brake the hub?
Old Oct 18, 2006 | 01:52 AM
vwfastg60's Avatar
The other night after lifting my 87 i thought i would make sure everything worked.I put it in 4wheel and started driving straight down the street.Well close to the end i hear this pop and a thud thud sound. i pull it out and unlock the hubs and it goes away. I thought i broke a cv but it all looks to be fine. I tried the 4wheel again lastnight planning on the snow today and thinking maybe it was a cv and i could crack it out. Well i lock the hubs and im in 2wd and im hearing the thud thud again. I put it in 4wheel and same thing. pull it out and unlock the hubs and the trucks fine. I figured i trashed something and tried putting it in 4 wheel with the hubs unlocked(not the best idea i know) no thud sound and everythings spinning fine.My friend watched under the truck as im driving and he says everything looks fine.
So the hubs locked makes the thud.What do i need to do to fix this cause its snowing and in 2wd the truck drives like poo.
I have 2 sets of hubs sitting here so i can replace it but i dont know what changes over
ones a dick cepek set that came with my IFS lift and the others a set of warn (how ever its all spelled)
Thanks
Russell
Old Oct 18, 2006 | 02:21 AM
AH64ID's Avatar
sounds like a CV.. hubs dont usually break... but pulling it apart will tell yo very quickly...
warn is best imo...
Old Oct 18, 2006 | 04:14 AM
waskillywabbit's Avatar
A busted hub would not induce a "thud" when the dial was turned...it wouldn't do anything. Sounds like you got a busted CV as when you "lock" the hub it engages the axle and makes it turn the busted CV, thus the "thud".
IMO, Warn manual hubs SUCK compared to the quality and strength of the OEM Aisins and they do not use the OEM cone washers, thus they are prone to loosening and backing off.
Old Oct 18, 2006 | 05:24 AM
mastacox's Avatar
Two words: nylock nuts
Old Oct 18, 2006 | 06:01 AM
bodo's Avatar
I've never broke a Warn or Aisin hub, I know they make alot of them and I'd rather break a hub instead of a birf, inner, or gear. One of the magazines had an article about hub fuses awhile back, made sense to me. I have warn premiums on now so I'm waiting for them to break.
Old Oct 18, 2006 | 06:20 AM
AH64ID's Avatar
My Warns have never come loose... The rest of the bolt world doesnt use cone washers, no requirment for them here.
Warn his discontinued their hub fuses... cant remember why.. but I posted it up here a few months back.. You probally wont break a hub, they are stonger than the rest of your drivetrain.
Old Oct 18, 2006 | 06:44 AM
millertime_t1's Avatar
To each his own-- but I really dislike Warn products -- I have broken probably half dozen sets of lock-outs (warn) <--- but they were being used on GM products--I've never used anything warn on a Toy --- Also of the half dozen Warn winches that I have owned -- I've never had one work twice in a row if I needed it --- something always fails on them
I have had good luck with superwinch lock-outs and winches--I've also had two Ramsey winches that just seemed absolutely unstoppable!!
Old Oct 18, 2006 | 05:14 PM
vwfastg60's Avatar
ok thanks guys. I guess i will pull it in and look closer.The axels have about the same milage as the truck i think. I got it at 80k when i was 14 and my mom drove it for a few years and never replaced anything and when i got it back the motor has been the only thing i replaced so far other then parts that go with the lift. When we were putting it all on the front drivers side inner joint felt like it was ready to pop out. When we bolted the diff up everything seemed fine. I did plan on replacing this because the boot was pretty dry.
Leviticus6432
Nov 20, 2015 05:06 PM
carlspeed
Aug 23, 2015 02:59 PM
priest16
15
Aug 6, 2015 07:43 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
