87 4runner 22re will not fire on second cylinder
Old Oct 8, 2006 | 10:42 AM
Jeff0076's Avatar
Angry 87 4runner 22re will not fire on second cylinder
my old head was worped so i got a brand new head put on my 22re. it runs and drives but the second cylinder is not working. this is what else has been done to it since then. the timing chain has been checked and it's fine.
comperssion test and all the cylinders read 160
leakdown test
new O2 sensor
put a different computer in it
new spark plugs and wires
new distributer cap and roater
new fuel filter
new injecter seals
had the head double checked to make sure it was put on right. no one knows what else to do to it. the mechanic just gave up and brought it back to my house. has anyone else had problems like this? i dont know what to do.
Old Oct 8, 2006 | 10:48 AM
AH64ID's Avatar
What do you mean by not working? No fuel, no spark?
I would make sure that you have spark first. Then make sure the injector works.. .maybe swap it with a different cylinder... if it makes the other one not work.. bingo..
Old Oct 8, 2006 | 10:49 AM
stock87's Avatar
I suppose the compression check kind of rules this out, but have the valves been adjusted since the rebuild? I worked on a 22R where the exhaust valve was just enough too tight that the cylinder wouldn't fire at idle.
Old Oct 8, 2006 | 07:42 PM
GrimReaper's Avatar
That guy has no business working on cars if he can't figure that out.
Move the #2 injector to a different cylinder and see if the problem moves. Check the harness. It batch fires. The #2 ground will join a second ground an then it will go to a ground lug on one of the bolts on the upper plenum between #2 and #3.
I really wonder if he got #2 and #3 Injector wire or maybe the cold start crossed up.
Old Oct 11, 2006 | 05:53 PM
Jeff0076's Avatar
i did have the injectors moved to different cylinders and the second cylinder still didnt work even with a different injector. ill get the grounds and the wiring harness checked.ill post again when i try those things and the valves have been adjusted. someone also told me that maybe the fuel regulater sensor or what ever it is called could have something to do with it?? thanks Jeff
Old Oct 12, 2006 | 12:24 AM
AH64ID's Avatar
Well if that injectoer works on another cyl and anther injector still doesnt work it sounds electrical.. But you still havent said why its not firing?? Do you have spark? fuel?
Old Oct 12, 2006 | 01:45 AM
Bigblock's Avatar
Could be the injector plug,try a noid light.or try wiggling the plug while it's running.
Old Oct 12, 2006 | 11:17 AM
Jeff0076's Avatar
sorry i forgot to say that but there is spark and fuel.
Old Oct 12, 2006 | 12:17 PM
rdharper's Avatar
I assume it is running very rough. I had a problem awhile back on my '85rec. The engine was running well, but without warning ran very rough. Pulling the valve cover off revealed a broken exhaust spring (on #2).
As the valve spring is necessary to open the valve, it is probable that the valve would close but not open, thus you would get compression. Not sure about that, as I didn't check it, so others should sanity check me on that.
Removing the valve cover is easy on the 22re. Replacing the valve spring turned out to be trivial as well, although I had it done for $200 including parts and labor. Has run fine ever since.
Old Oct 12, 2006 | 10:58 PM
Jeff0076's Avatar
well i got a brand new head and the valves are adjusted so i know that they are good
Old Oct 13, 2006 | 01:25 AM
AH64ID's Avatar
If you have fuel, spark and compression... its something to do with the valves most likly... just becuase the head is new doesnt mean something can be wrong with it....
Old Oct 13, 2006 | 10:36 AM
Jeff0076's Avatar
ok, ill get that checked out again and ill post when i find out. thanks
Old Oct 14, 2006 | 07:01 PM
Jeff0076's Avatar
its not the valves, they were all checked and adjusted
Old Oct 15, 2006 | 02:16 AM
AH64ID's Avatar
Well if you have fuel, spark, proper valvetrain timing.. you should be firing.. I would find a new mechanic..
Old Oct 16, 2006 | 05:35 PM
GrimReaper's Avatar
Do a compression check and swap the #2 Plug wire to a different cylinder.
Old Oct 16, 2006 | 05:51 PM
millertime_t1's Avatar
leakdown test
new O2 sensor
new fuel filter
new injecter seals
If it's getting spark and fuel and it has 160psi - it sounds like #2 is working just fine. WhaT diagnosis has led you to believe its not?
Old Oct 16, 2006 | 10:39 PM
84sr5yoty's Avatar
Check this thread out. Pics are on the second page.
http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
Old Nov 16, 2006 | 03:46 PM
Jeff0076's Avatar
it ended up being the wiring, the were a few different wires that were broken or touching other wires. thanks for the help
Old Nov 16, 2006 | 06:44 PM
AH64ID's Avatar
Glad you finally got it figured out..
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
