Coil spring spacer price difference
I am interested in lifting my truck with the coil spacers, and ball joint spacers. The price on 4Crawler.com for the coil spacers are $90. But when I was at my local auto parts store I noticed they had these same spacers (At least they looked the same) for just $13. Could they really be the same thing?
They do fit just fine, its just that I want my truck bigger and dont have the money to go for a suspension lift yet. I'd like to do the balljoint\coilspacer lift. I was just wondering if anyone had boughten a coilspacer from an auto parts store, and had it been the same product 4crawler.com sells.
I'm sorry im completely new to this, if I were to buy larger springs to lift me 2" past stock ride height, would I have to get longer shocks too?
I dont like the idea of a bodylift mainly because of my grille guard, and I want to get my gas tank, etc. up higher from those rocks.
I bought allpro offroad 1.5 inch lift springs and I didn't have to get longer schocks, or brake lines. And they are about 150 plus shipping. They made a really big differance both in how my 4runner looks and how it carries any kind of trailer weight.
Did you flex the rear out and make sure that the stock shocks are long enough and not limiting your droop ?
If you're not concerned with droop, that is really don't wheel much, then the stock shocks, most likely, will work just fine.
If you don't get new shocks to take advantage of any additional droop that you make have, then you won't need longer brake lines with 1 1/2" ~ 2" of lift.
Fred
A suspension lift (we're talking about the rear) can come as longer springs or spring spacers, it's *basically* the same.
Sounds like you haven't thought things through at all.
With the 2" suspension lift, you'll need not only longer shocks (if you want to take advantage of the lift), but you'll also have to do something with the LSPV and the trackbar.
With a bodylift, you can raise not only the gas tank, but also the xfer case/tranny and still keep the COG relatively low.
Grill guard aside, you may wish to consider a bl.
Fred
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
