Porche CVs
Old Oct 10, 2006 | 02:55 PM
Yotatuff's Avatar
Porche CVs
Does anybody have any information on these? I heard they would fit on a toyota and are stronger then stock. Is this true?
Thanks
Dustin
Old Oct 11, 2006 | 04:41 AM
Bdog's Avatar
call Downey offroad
and have a chat with those guys they seem to know a little about the subject.
Bdog
Old Oct 11, 2006 | 11:43 AM
Yotatuff's Avatar
Thanks I will.
Old Oct 11, 2006 | 12:19 PM
KyleT's Avatar
lucky for me, i work for porsche...
Old Oct 11, 2006 | 01:13 PM
jon_7248's Avatar
I beleive those are stronger and thicker in diameter. However, they are not as less expensive as the T100 axles that can also be used in the LongTravel kits.
Old Oct 11, 2006 | 01:17 PM
turboale's Avatar
I'd also suggest looking into the VW Toureg CVs... probably are marked up *slightly* less than the porsche parts...
Old Oct 11, 2006 | 01:25 PM
Yota82's Avatar
Most of the axles are using Porche 930 CV's and 934 CV's. The only real purpose of them is for CV angle. Basiclly for long travel applications where CV angles are giong to be more so than a stock CV.
Old Oct 11, 2006 | 01:44 PM
jon_7248's Avatar
Wonder what the advantage over the T100 axles are versus the Porche. I know Porche are stronger, but unless your in the Baja 100 or something, can you break the T100 with the 12" of travel? Im no LT knowing man
Old Oct 11, 2006 | 01:49 PM
CJM's Avatar
CJM
I wonder how tough they are indeed since I got a T100..only one way to find out for myself.. I'll be back in a few lol...
Old Oct 11, 2006 | 02:18 PM
YotaFun's Avatar
Don't be goin to do to much damage now.....
Old Oct 11, 2006 | 02:46 PM
CJM's Avatar
CJM
Lol...its raining like crazy here..but no place to go unless I wanna drive quite a ways..
Old Oct 11, 2006 | 02:52 PM
YotaFun's Avatar
Okay.
lol...
To bad your not near me...
I know of a good place you could test it out about 10 min away from me...
Makes me wish the Runners Brakes were working...
Then I would be out there....
Cause tis pouring rain here too!!!
Old Oct 11, 2006 | 05:37 PM
Yotatuff's Avatar
So does anybody have a price on the Porche 930 CV's and 934 CV's. How hard are they to put in a stock truck? I didn't have time to call Downey, had to work.
Old Oct 11, 2006 | 06:21 PM
KyleT's Avatar
i can look it up tomorrow... prolly expensive as it says "Porsche" on it....
Old Oct 11, 2006 | 06:53 PM
95RunnerSR5's Avatar
last i heard was somethin like $400 a pair, just get some stock ones from your local store, they most likely come with a lifetime warranty
Old Oct 12, 2006 | 07:37 AM
deathrunner's Avatar
Ok, here's a little info.
The T-100 cv's are exactly the same as the IFS cv's. They just have a longer shaft. LT comapnies knew this so, they built thier LT arms to the same length so that we could use a readily avilable part to save on cost. Strength is the same as stock.
Porsche cv's can handle better angle and more power (Stronger). You cannot use stock porsche cvs as the mounting holes will not line up. The ones made for Toyotas are adapted to fit, or I believe in Downey's case use some sort of adapter between them (That's how it sounded to me).
Are they worth getting? Did you break one?
Old Oct 12, 2006 | 08:35 AM
Sonofmayhem's Avatar
they are expensive, i remember hearing 900 for a pair, but look on ebay too... yes you can break stock axles, when your running a supercharged 3.4 lt truck with stock front t100s threw the desert anything can break.
Old Oct 12, 2006 | 12:01 PM
snap-on's Avatar
or your at full lock on 35's with a front locker....
Old Oct 12, 2006 | 01:51 PM
KyleT's Avatar
i would have to find out which one they are using, there are a couple differnt ones, about 390 retail though.
Old Oct 12, 2006 | 03:19 PM
norcalsvx's Avatar
they run the 930cv's on a lot of dune buggies (lt)
