oil level question
Old Oct 16, 2006 | 06:49 AM
swerks's Avatar
oil level question
86 4runner, Does oil level measure higher or lower when cold. I let dealer do a oil change and suspect overfill.
Old Oct 16, 2006 | 06:54 AM
millertime_t1's Avatar
The most accurate reading would be cold --- But checking hot is not innaccurate --(fluctuations of 1/2 quart)
Old Oct 16, 2006 | 07:25 AM
swerks's Avatar
I was always taught to read oil with a warm engine
Old Oct 16, 2006 | 09:23 AM
pat161's Avatar
Well the question is where does the dipstick read from. I was always under the impression it read from the oil pan, so if the engine is running or just turned off the oil may not have completely drained, therefore it may read low. But the oil should be mostly drained within a minute or two, so checking a warm engine, like after you fill the gas tank, should be fairly accurate. As for over filling, I would not worry if it is just a little over the mark, an extra 1/4 quart of oil will not be enough to blow seals or whip into a foam in your crank case. Now when I was a kid I added twice the oil to a motorcycle, long dumb story, and lets just say I learned an expensive time consuming lesson.
Old Oct 16, 2006 | 03:11 PM
surf4runner's Avatar
oil will register higher on a cold engines dipstick
it drains out of everywhere back to the pan.
Old Oct 16, 2006 | 03:53 PM
ovrrdrive's Avatar
Oil is always checked with an engine at proper operating temperature...
This per the manual:
Old Oct 17, 2006 | 02:10 AM
swerks's Avatar
dealer informs me of leaking gaskets then overfills by almost 2 qt. this cant be helping my leak problem
Old Oct 17, 2006 | 04:54 AM
AH64ID's Avatar
It depends on how soon after you shut down you read it. Immeadialtly it will read lower as the oil is in the block still.
About 5 minutes aftershut down you get a good warm reading which will read higher than a cold reading as the warm oil is expanded and takes up much more room.
Overfilling is not a good idea. Just motiner your oil at the proper level, add when neccessicary
Old Jun 10, 2013 | 07:38 AM
Larz28's Avatar
oil level
on a 22RE, after the engine has been off for5 mins, is the oil level in the pan above, right at, or below the gasket ? I guess I should have stuck my dipstick in while I had the pan off to find out. Just curious.
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
