Cig Lighter Fuse Location?
Ok, well now I'm lookin for the cig lighter fuses, cause it's really driving me crazy not being able to charge my phone lol... Anyhoo, if you could clue me in to the location and amperage of the fuse (have a haynes, but no owner manual ), I'd be very thankful.
did you check all the fuses
i know that my cig lighter only works when the key is in start..
also i have to rotate my charger in a certin position for it to work..
Yeah I tried all of regular doodads. Used my car charger which lights up while twistin it all around while the key is in the on (not acc) position. But nah I haven't checked all the fuses, just the one 15a fuse, which looked dandy.
If I recall correctly, there was only one 15a fuse in my kickbox. And my radio is running, so I really have no idea... Is the cig lighter fuse seperate from the radio fuse by any chance?
well if the radio works then it is most likely not a fuse but a contact take a screwdriver and scrape ot the lighter socket to start some times they get fouled up pretty bad.
also has it ever worked and do you have a CB or some aux device setup?
rushw
07-18-2015 01:46 PM
