PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 [219] 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Failed CA Smog b/c of timing!
  2. $77.00 Paint job... PartII
  3. bumper issue
  4. Pictures of my rebuild
  5. cold start injector washers for a 22re
  6. Clos' 1988 4runner
  7. help me find some wheels....
  8. 22RE Engine with 120,000 miles for sale in vegas
  9. Changing the CPU with others , does it have to have same part# on it
  10. Main Bearing Headaches
  11. Lights in rear bumper.
  12. Charge, brake and A/T Oil Temp Light on
  13. good lift?
  14. Keep my truck or get newer one?
  15. dual battery set-up prep
  16. Some general questions
  17. thread about my truck since i never posted one
  18. installed some add-a-leafs
  19. Help Help! Wont start!!
  20. Question on A arms
  21. any rock slider pics
  22. Aftermarket VAFM scam
  23. 89Runner 4WD Noise/Clunking/Plz help
  24. [b]spark Plug Wires[/b]
  25. 1990 4runner 2dr repair or resale?
  26. pics of V6 intake mani
  27. Newbie, Rear window...
  28. Speaker Size ?
  29. radiator replacement
  30. 4Runner Pics
  31. hard start when cold, and smell of fuel
  32. Power steering problems
  33. Pulled the trigger for a winch
  34. well if anyone has back window
  35. 91 ext cab up and quit, need a little help
  36. AFM opps :(
  37. help with siezed bolt
  38. CV Axle replacement help
  39. Deer+ARB
  40. Stock White Steel Wheels
  41. Brush guard at Harry's You Pull it Hazleton PA
  42. Changing gears hard???????????
  43. Converting 4wd 4Runner to 2wd prerunner
  44. stock gears for 33s?
  45. Help with Trouble codes
  46. Fan switch out of 86 work on 89?
  47. No power to Cold Start Injector
  48. ive looked
  49. Hang used doors before or after painting?
  50. wire gauge for power window motors?
  51. My 3.0
  52. Coolant leak
  53. yukon gears, are they worth it?
  54. starter removal on 85 2
  55. 1988 Toyota 4runner
  56. Nice Lookin'...
  57. Dash Cover Lens Removal
  58. Suspension Help!!!!:(
  59. 85-93 22RE Differences???
  60. starting issue
  61. my new window tinting! 145 bucks!
  62. Sway bars disconnected?
  63. New head advice
  64. 3rd gen truck production dates? Do I have the last one?
  65. Front Seatbelt Retracted Too Far
  66. Where could I go to purchase 4.88 gears?
  67. Cabin air filter on a 92
  68. Starter Issues
  69. 89 22re Cold Start
  70. Need 12 volt 10-amp switched wire
  71. I found a 92
  72. 89 3.0 Distributor eating itself
  73. Cooling system refill
  74. Questions about my 86 4runner
  75. regearing for 33s?
  76. Please tell me this fits my truck
  77. glove box 4x4 shifting decal
  78. q's about my 89 toyota pickup
  79. Cracked lower control arm, help!
  80. 1988 4 runner that needs help please
  81. does adding leaves to a sagging spring pack stiffen the ride?
  82. Signs of bad ball joints?
  83. Noise in transmission like marbles, here's why
  84. Problems with 93 3vze
  85. This is what a buick V6 sounds like in a toyota..
  86. odd problem
  87. Seafoam in the crank case.
  88. Suspension Gurus, I need some help ASAP
  89. m8000 ordered
  90. inchwrom adapter plate seal????
  91. Monster Project!!!!
  92. bull guard and fender flares
  93. 95 4runner brakes
  94. regular cab into extra cab
  95. How hard is it to drop 2gen Gas Tank??
  96. Bought a wiring harness to swap into my truck. Problems!!!!
  97. Coolant boiling on my 94 v6. Mechanic says it's not a problem.
  98. Introduction and AFM/idle question
  99. Just for fun....goofy horn
  100. 30x9.50 or 31x10.5?
  101. High pitched interior squeeks
  102. v6 to v4
  103. Ready to execute my engine!!!
  104. Installed the HELLA500s on the pickup..nothing fancy
  105. Problem with EGR modulator?
  106. V6 heads & bottom end???
  107. Broken coupling in steering column --help!
  108. [B]Wiring 3.4 5vzfe swap into 4runner[/B]
  109. Remaned 22re
  110. Rear bumper question
  111. I need help figuring out my idle problem
  112. Help me pick out a horn setup for the pickup....
  113. 89 Diesel 4x4 Toy
  114. Tired of water in the cab.. Door sealing options??
  115. guys that live in canada ontario
  116. bumper
  117. new and ride a 88 pickup
  118. 2nd Gen 4runner OME lift
  119. axel ?
  120. Fender switch!
  121. squeeling noise ?
  122. land cruiser wheels?
  123. What Cam to Choose
  124. Seattle Area Machine Shops?
  125. Advice on what to pay for body work?
  126. Supra Engine Swap? Anyone Done It?
  127. Changing Spark Plugs (TUNE UP) Time
  128. 1UZ-FE or not to 1UZ-FE, that is the question.
  129. 4runner Didnt Pass Smog
  130. um anybody know what this is
  131. Front drive shaft problem
  132. Stock bolt size for gas tank ?
  133. Is the 3.0L a good high mileage engine?
  134. Truck has trouble starting!!!Some HELP!!!!
  135. Front Lockright on ifs-How is it?
  136. New Radio install problem
  137. Factory 4.30's?
  138. Anyone have any before and after pics?
  139. 3.4L donor vehicle
  140. Supra Engine Swap
  141. Help w/ my new '94 4runner
  142. 2000 tacoma elocker in a 94 4runner
  143. i think my fuel pump is going bad
  144. keep blowing efi fuse help
  145. turbo a 22re ???
  146. A question for the Turbo guys
  147. my latest project
  148. CB Radio?
  149. Redline?
  150. Pro comp light bar
  151. Thinking of losing the lc coils...
  152. 2wd rear - too stiff
  153. 88 1st Gen Tranny Question
  154. Advice On Saggy Rear
  155. 87 4runner Engine Swap Problem
  156. Gear ratio math
  157. Steering making weird sound
  158. Which Hawk pads are people running?
  159. intake support arm HELP ASAP 22re
  160. Custom front valance and receiver for 2nd Gen 4Runner
  161. metering device (rich and lean) engine code?
  162. Valve Shims for trade or sale? 3VZE
  163. suspension advice please
  164. Body lift...difficult?
  165. 35x10.50s with my minor lift?
  166. Heater Question
  167. brush guard
  168. HEEEEELLLLP!!! installing gone bad
  169. timing off a tooth and caused glowing exhaust. now have water in oil plzz help
  170. Woo hoo!
  171. Saturday doin's
  172. A 1990 4Runner 3.0 V6 with a fuel leak, what a shock..
  173. Tight fitting fue njectors, help
  174. Leakin fuel!!!
  175. anyone need a 3.0 complete wiring harness?
  176. Thoughts/opinions re sinking some $ in an 88 4Runner
  177. 4WD Issues
  178. My 94 22RE wont idel
  179. How do I bypass rear window requirements?
  180. Getting a new yodaman motor installed.
  181. Muffler / Cat. Converter Swap.
  182. 3.0 L 3VZ-E V6 head gasket problem...
  183. Quick Easy DIY tail and blinker lens clean up
  184. SEAFOAM causes leaks?
  185. Stuck in low range wierd chattering slipping
  186. Looking for Cheap valve spring compressor
  187. I tried Sea Foam Motor treatment today
  188. Strange overdrive problem
  189. A couple quiestions please
  190. Brake Upgrade..Using T-100 parts?
  191. 4WD LOW question
  192. Timing chain
  193. Im So Fed Up
  194. HELP!!! Im stuck installing Skyjacker shocks
  195. rust protection
  196. Lets talk T100 vs mini truck front diff
  197. Spare Tire Carrier - - - HELP
  198. trails with camp sites in ontario
  199. steering problems
  200. 3 Yota's in 1
  201. HELP!!! my valve train won't shut up!
  202. ***End of Summer wheelin' PICS***
  203. Oil oozing from throttlebody?
  204. Sleep/Cargo Platform Ideas (LIGHTWEIGHT)
  205. pics of my toy
  206. Shoot Some Help My way .... P(u)Lease
  207. 33 x 12.5 on stock rim?
  208. Help wiring lights
  209. 22RE Question
  210. Done HG replacement - clutch pedal is now dead??
  211. Need Help!! with my new 4runner (not making power)
  212. Any clue what this locker fits?
  213. parts
  214. sas d44 questions
  215. people that live in canada ontario come here
  216. Any fix for V6 Cluster on a 22re?
  217. Anyone have a copy of valve clearances?
  218. Just Thinking, Pirate 4x4 is a rough place
  219. frame work?
  220. Custom manifold exhaust pipe?
  221. Broken 1991 4Runner need advice
  222. need me a bumper
  223. Jerry rigging knock sensor wire
  224. Looking at a 2nd gen
  225. 1st Gen 4Runner Toy/Model
  226. 22r v.s. 22re on 88" t100
  227. Frickin Spare tire hanger
  228. Brake Light
  229. downey intake
  230. Come on Guinea pigs - get those 3vze LCE Headers!
  231. Rebuilding motor? whats needs done to block?
  232. Largest Spare Tire Allowed
  233. Check Engine Light
  234. Questions Please Help =-)
  235. gearing / bender?
  236. need help...broken nipple on TVV on coolant manifold on back of 3vze engine
  237. diff drop vs. ifs truss
  238. Motor work ?'s
  239. Dropped socket in the block :(
  240. New brush guard, old bumper
  241. OBA pressure s/w
  242. forum for 1991 4runner
  243. I know this has prolly been asked
  244. Aww yeah, jumpin a toyota truck! *video*
  245. Yakima Track Install
  246. Help please.
  247. Head Bolts about to break!
  248. 3vze maximum timing advance stock engine
  249. Rancho Add-A-Leafs
  250. my 86 surf/4runner!
