Help wiring lights
Old Sep 19, 2007 | 11:14 PM
nix4x4's Avatar
Help wiring lights
Thanks to ROCK SLIDE, I just got a set of KC lights. I want to mount them in the rear for exra backup lighting when I need it. However, I want to be able to control the lights via switch in the cab so I can use them when I want and not blind everyone around me when they arent really needed. I'm not really too electrically-inclined, so I was hoping you guys could help me out here. What's the best way to wire the lights to be controlled by a toggle switch or something like that inside the cab? Any help is greatly appreciated.
Old Sep 19, 2007 | 11:21 PM
ozziesironmanoffroad's Avatar
it comes with the switch right? if so, i mounted mine right above the cluster light dimmer switch. connect the 2 lights together, put a fuse between them, then run that to the switch. then run a ground to either an unpainted part of metal OR the negative battery, it doesnt matter which. then run a single wire to the positive post of the battery. then its done.
Old Sep 19, 2007 | 11:29 PM
corvey's Avatar
Mount the lights, run one of the wires to the frame somewhere as a ground, then run the other wire to the dash or wherever you want the switch, then on the other side of the switch run another wire to a 12v wire coming from a hot source in the dash with an inline fuse, such as a cigarette lighter. Do NOT use a cheap thin wire, use a good rated 12 gauge wire as the power from the lights may suck a lot of juice if the wattage is high.
Old Sep 20, 2007 | 01:04 AM
PoconoJack's Avatar
http://www.kchilites.com/faq/instruc...517_backup.pdf
That should do ya...
Old Sep 20, 2007 | 01:29 AM
Elton's Avatar
this should help http://www.4runners.org/image/hella5...auxfusebox.jpg
Old Sep 21, 2007 | 05:58 PM
nix4x4's Avatar
Cool Thanks alot everybody hopefully they'll be going on the truck sometime soon
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Johntom240
7
Jul 13, 2015 12:18 AM
