intake support arm HELP ASAP 22re
Old Sep 23, 2007 | 08:37 AM
gametom's Avatar
so i was putting the intake back together and i don't remember where this was attached because when i took the intake off it was just hanging (the previous owner must have done some intake work) o it's a 91 4runner 22re 5speed
Thanks
Old Sep 23, 2007 | 09:01 AM
8yota9's Avatar
it gose down the side of the fender above the stering box ataches to the side of the intake box and the side of the wall.
Old Sep 23, 2007 | 09:05 AM
DeathCougar's Avatar
Sorta....
It attaches to the middle of the intake at the top, and the pass side motor mount on the bottom.
The motor mount should have an open hole, hence the welded but on that intake support bracket.
Old Sep 23, 2007 | 10:09 AM
gametom's Avatar
is this where it attaches
Old Sep 23, 2007 | 10:34 AM
yes. From there to the motor mount.
Old Sep 23, 2007 | 10:36 AM
gametom's Avatar
Sweet Thanks
Old Sep 24, 2007 | 06:45 AM
4Hummer's Avatar
Picture is worth a thosand words
Old Sep 24, 2007 | 11:20 AM
I love that you have an oil COOLER mounted next to a block HEATER lol.
Old Sep 25, 2007 | 06:50 AM
4Hummer's Avatar
Figured it was the best place to put it. that way in the winter the Oil in the Filter will be a bit warmer on startup, along with the Coolant.
It gets to minus 30C here in the winter.
Old Sep 25, 2007 | 06:57 AM
gametom's Avatar
ya that's where i put it.
by the way i like the red 22re.
maybe i should make one ether blue or yellow.
what kinda paint did you use on the block?
Thanks for the help
Old Sep 26, 2007 | 05:29 AM
4Hummer's Avatar
Thanks for the help
Plain High Heat engine paint. Motomaster Brand (Canadian Tire)
Red and Grey.
RatOmeter
Oct 22, 2015 03:17 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
