89 22re Cold Start
Old Sep 27, 2007 | 04:15 AM
NEWMOVEMENTRIDER's Avatar
89 22re Cold Start
The Truck Doesnt Start when The Engine Is Cold Untill After About 5 Min. Of Trying To Crank It. Once The Motor Is Warm It Will Crank Right Up Every Time. The Battery Is Good. Thank You
Old Sep 27, 2007 | 05:05 AM
YotaJunky's Avatar
sounds like you've got a problem with the cold start injector or switch, or both.
Old Sep 27, 2007 | 05:13 AM
I Called The Parts Store And They Have A Cold Start Injector Valve, Is That What Your Talking About. Thanks
Old Sep 27, 2007 | 05:56 AM
rdlsz24's Avatar
You can also check the wires going to a brown plug and a green plug on the front of the intake just below the throttle body. Mine came loose a while back and then it had trouble starting cold before I fixed it. Try the easy cheap stuff first before buying parts.
The plugs have a red box around them in this picture:
Rob
Old Sep 28, 2007 | 01:16 PM
84sr5yoty's Avatar
Nope, the cold start injector time switch. The cold start injector time switch signals the cold start injector when to cylce on. Cold start injectors almost never go bad, it's cold start injector time switch that's the common culprit.
Old Sep 28, 2007 | 01:30 PM
4runnerx3's Avatar
Old Oct 1, 2007 | 09:52 AM
Thanks For The Picture, That Helped Me Out Alot. I Noticed The Ground Wire From The Negative Terminal To The Body Was Shot And The Ground To The Chassis Was Pertty Oxidized So I Changed The Body Ground And Cleaned The Chassis Ground And It Cranked Up Perfectly With No Hesitation The Next Mornin When The Motor Was Cold. But Then Yesterday It Took 2 Tries To Crank It, Which Is Still Way Better Than Before I Changed The Wire. I'm Prolly Still Going To Order The Switch Though
Old Oct 1, 2007 | 09:19 PM
94 yota Ed's Avatar
Im having the same problem. I posted this queston, if I jumped the time switch plug, shouldnt the truck start right up if the switch was bypassed?
Not to run it like that just to see if the switch is working or not.
Old Oct 31, 2011 | 06:30 PM
danieljolley's Avatar
Im having the same problem with my 91. Does your truck smoke like its dumping fuel? I also can smell gas really bad. Did anyone have results when replacing the cold start injector?
bigjstang
Jun 2, 2025 03:56 PM
Yota.Jay
Jul 23, 2015 08:08 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
