um anybody know what this is
Old Sep 24, 2007 | 08:17 AM
gametom's Avatar
ok so looking over all my wiring i found this connector packed with mud and traced it to this thing in the front of my ifs i wasn't plugged in to anything on the other end and hasn't been for a wile. so my questions are 1 what is it? 2 is it important? 3 where should it plug in?
Thanks
Old Sep 24, 2007 | 08:20 AM
dropzone's Avatar
Fossilized
Does you 4x4 light work? Just a guess...
Old Sep 24, 2007 | 08:26 AM
gametom's Avatar
4x4 light?
Old Sep 24, 2007 | 08:29 AM
Toyvana's Avatar
Your green dash light when 4WD is engaged.
Old Sep 24, 2007 | 08:30 AM
Gator's Avatar
Originally Posted by gametom
4x4 light?
When you put it in 4x4 does the green light show up on your instrument panel?
Also, i this possibly linked to that ADD that I have been reading about? No clue, just asking?
Old Sep 24, 2007 | 08:32 AM
mt_goat's Avatar
Yep, that sends the signal from the ADD actuator to the dash light that the ADD has been locked into 4WD. IIRC the other end should be plugged in up around the oil filter but I could be wrong on that. Other than the 4wd dash light everything should work ok with it unplugged.
There's some mention of it here:
http://www.4x4wire.com/toyota/tech/add/
Old Sep 24, 2007 | 08:42 AM
gametom's Avatar
i never knew it had a 4x4 light sweet
Old Sep 24, 2007 | 10:48 AM
breknraj's Avatar
Mine came apart years ago - the locking tab broke off. I just put the plugs back together, and then I ran a small zip tie around both of them, between the wires on each side, to cinch it together. It has never been a problem, since.
Old Sep 24, 2007 | 02:36 PM
faubrunner64's Avatar
yes te connector is right up by the oil filter and it is the 4x4 light
Old Sep 24, 2007 | 02:39 PM
OSU4Runner's Avatar
HaHa...
